Thread: P0171 help please
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: P0171 help please
    Vacuum should be a lot closer to 20 you have a vacuum leak somewhere
  2. #22 Re: P0171 help please
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    i can hear a hiss coming from the brake booster area tried carb cleaner and no rise in rpm if i block the hose and moniter my fuel trims should i see a change if that is where the leak is coming from?
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  3. #23 Re: P0171 help please
    The hiss its a vacuum leak. Try pushing in on the vacuum line running to the brake booster
  4. #24 Re: P0171 help please
    Whenever your fuel trims are reading 16.4, that's a vacuum leak.
    Find it and fix it.
    Also, 97-98 TB/MAF have to be year specific.
    So you'll be needing a 99-03 TB/MAF.
  5. #25 Re: P0171 help please
    Sep 2012
    bridgeport,NY
    UPDATE- replaced lim gaskets, installed zzp coupler, ported and polished intake and blower, tested maf( good reading), replaced pcv, cleaned all grounds and battery terminals, ran cam2 for a couple weeks, and plugged acc vacuum port. my question now is can the map sensor be bad cause that is were the hiss is coming from?
  1. 98 GP GT 3800 with P0171 off and on?
    By Fritcr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-31-2012, 01:05 AM
  2. p0171 help
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-14-2012, 08:07 AM
  3. Hi I'm new and have a p0171 code, can you help?
    By falconjohnd in forum Engine
    Last Post: 12-15-2011, 07:45 AM
  4. P0481 & p0171
    By Biohazed in forum General Tech Discussion
    Last Post: 04-26-2011, 09:51 PM
  5. p0171
    By sca555 in forum General Tech Discussion
    Last Post: 04-03-2011, 02:37 PM
