My 98 GTP supercharger is rattling at stop lights and searching indicates bad coupler.
However the supercharger is also causing my engine to loose power - where sometimes I can barely make it up a hill. I thought it was my transmission not downshifting and was planning for a rebuild but the previous couple of days I took the SC belt off and it drives perfect only lacking a little bit of power due to no SC.
The SC pulley seem to spin nicely - are my SC rotors bad? The SC makes a loud rattling unnatural sound every time I turn the engine off as if things are clunking into each other. Are there other SC parts that can cause power loss? I am not sure why the engine RPM stays under 2000 sometimes when I hit the gas even if I floor it and the boost indicator is coming on.
Am I ok to drive with the belt off for a long while?
Thanks.
