Thread: Walmart 93 Octane Gas
Results 1 to 20 of 21
  1. #1 Walmart 93 Octane Gas
    Aug 2012
    Danville
    Walmart has the highest octane gas in my area for the lowest price. I've read comments on here about shell gas quality for the 3.8L SC engine. What brand of gas seems to run the best?
  2. #2 Re: Walmart 93 Octane Gas
    its all up to how your car runs on the gas your buying.
    i have 2 deltas by me one is real cheap and one is right across the street from me, i had been going there for over a year.
    then i was real low, so i stopped at another delta, (other side of town) and my car felt like it just got real gas, the other station is selling crap, either way i no longer go to the cheap station by me because they sell sh1t gas.
    and i ve seen the tanker come to fill both stations, different tanker trucks, i found that odd. so my guess is they are both privately owned franchises and buy their gas from where ever they want too. not all gas is equal, i found that out first hand.
  3. #3 Re: Walmart 93 Octane Gas
    I don't run walmart gas because on my old car i lost about 3 mpg when using it. Not worth the $.05 a gallon i was saving. I now always use the shell gas in my gtp since i get the least KR off of it.
  4. #4 Re: Walmart 93 Octane Gas
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    Wal-Mart sells Gas stateside? Weird!
    Yea, I find not all gas is the same..gas is not gas. Try a few different stations/brands, see what works best for you, performance and economy wise.
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  5. #5 Re: Walmart 93 Octane Gas
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Does anyone see any benefit of buying from a station that advertises "Top Tier" gas? I seem to get a little better mileage in my 03 GT.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  6. #6 Re: Walmart 93 Octane Gas
    find gas with zero ethanol.
    that'll net the best fuel economy.
  7. #7 Re: Walmart 93 Octane Gas
    Former GP Owner Chadgervais's Avatar
    Sep 2012
    Bangor, ME
    yeah... if only. Everyone in my area has that 10% ethanol stuff since maine outlawed MTBE. Mobil and Shell are my primary stations. Citgo is ok, but i dont like my money going to Hugo Chavez. Gulf, Sunoco, and Irving are all bottom of the barrel.
    BTW, Mobil Shell and Chevron are all "top tier".
    FORMER GRAND PRIX OWNER- NO LONGER ACTIVE ON GRANPRIXFORUMS.NET
    YOU MAY PM ME WITH QUESTIONS, WILL ANSWER TO THE BEST OF MY ABILITY
    FORMER RIDE: 2004 GT2, TRADED WITH 244,338 MILES. CURRENT: 2012 DODGE AVENGER
    GOD BLESS...
  8. #8 Re: Walmart 93 Octane Gas
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    non ethanol is great but costs more. i saw 1 to 2 more mpgs with it. you can also get k100, its a fuel additive that breaks down the ethanol and removes moisture from the gass
  9. #9 Re: Walmart 93 Octane Gas
    Aug 2012
    Danville
    Thanks for the replys. I'm in Iowa and most have the ethanol additive and some only have that. Walmart here only has the ethanol additive and sells the 89 and 93 octane. Shell has 91 octane and is non-ethanol. I havn't driven my GTP enough to tell much difference between gas fillups. I just switched from the Walmart 93 to the shell 91 and thought I would see if it helped knock retard.
  10. #10 Re: Walmart 93 Octane Gas
    GTP Level Member
    springfield IL
    Our walmart (murphy) gas station only has 91 octane as there highend gas.... I do notice a drop in mpg when i 87 octane gas.
  11. #11 Re: Walmart 93 Octane Gas
    Break down the octane booster in your fuel? Sounds like a bad idea.
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    And I thought 92 was bad. While it seems I can only find 93 at a few stations the Sunoco by my old place had 94 on the pumps and 104 at a side pump during the summer but it has lead. just recently have they disappeared
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  13. #13 Re: Walmart 93 Octane Gas
    Sep 2012
    bridgeport,NY
    ^^ what reread my post please
  14. #14 Re: Walmart 93 Octane Gas
    Quote Originally Posted by rperry435 View Post
    104 is race gas. i bet it cost like 8 a gallon lol
    94 would be ideal, anything 91 and up is what your engine wants, if your supercharged that is, you n/a guys just run the cheap 87 all day.
  15. #15 Re: Walmart 93 Octane Gas
    Quote Originally Posted by Erik Adam Rodriguez View Post
    Ethanol boosts the octane rating.
  16. #16 Re: Walmart 93 Octane Gas
    Sep 2012
    bridgeport,NY
    clarify how that works when two fuels are 91 octance and one has ethenol what you might be thinking of is methenol
  17. #17 Re: Walmart 93 Octane Gas
    Ethanol is of a higher octane and its commonly used to bump up the octane of fuel in stead of MTBE. Its not nearly as toxic, and is already compatible with most fuel systems in concentrations up to 10%.
    Is also responsible for slightly reducing cost of fuel.
    So if you're removing that from your 91 octane, it isn't 91 octane anymore. It'd be less.
  18. #18 Re: Walmart 93 Octane Gas
    Sep 2012
    bridgeport,NY
    very good info
  19. #19 Re: Walmart 93 Octane Gas
  20. #20 Re: Walmart 93 Octane Gas
    I find my car runs best on Exxon around here. If I don't have time to stop there I go to Loaf N Jug.
  1. Replies: 37
    Last Post: 06-25-2012, 10:37 AM
  2. DIY Walmart Window Tint...Hmmm...
    By selym17 in forum Visual/Body Modifications
    Last Post: 06-04-2012, 09:54 PM
  3. Walmart in the News again
    By cincygoat in forum Off Topic Discussion
    Last Post: 03-17-2010, 07:12 AM
  4. if others think walmart/target etc is funny check this out
    By imdaman3 in forum Off Topic Discussion
    Last Post: 03-06-2010, 10:59 AM
  5. Car Damaged by walmart shop
    By SDGTP99 in forum The Rant Forum
    Last Post: 07-25-2009, 12:32 PM
