Thread: 1999 gtp 3.8 sc p0305 #5 misfire
Results 1 to 4 of 4
  1. #1 1999 gtp 3.8 sc p0305 #5 misfire
    Sep 2012
    United States
    I can't figure out why I'm getting this misfire for the life of me. When you first drive the car when cold and hit the gas the car runs like a brand new one. After it gets hot and you kick it it misfires has low power at full boost. When I would stay on the gas for about 3 or 4 seconds the Service Engine Soon light would flash and then it would stay solid. at first i was getting a P0303 and a P0305. Since messing with it it has calmed down to a P0305 everytime. I have changed the spark plug, wire, coil pack, and fuel injector. It only does this when Supercharger boosts. If i drive the car without ever needing boost it will not misfire. I did a compression check on the cylinder and it passed. I also had my Ignition Control Module tested and it checked good. So I honestly have no clue where to go from here? This problem kind of happened suddenly one day when i started up the car. When we hooked up the fuel pressure guage, the needle was erratic around 44psi If we dissconnected the vaccum on the regulator it steadied a little but needle still was very shakey, never steady.
    This is a $400.00 AC/DELCO aftermarket fuel pump. Would like some feedback before this investment is purchased and then did nothing to rectify the problem.
    I have access to all diagnostic tools that would be needed for any test suggestions.
    Thankzs!
  2. #2 Re: 1999 gtp 3.8 sc p0305 #5 misfire
    Hook up and watch Knock Retard. Sounds like you are getting a good amount. Reason why you don't get it cold is the knock sensors aren't active until 160F
  3. #3 Re: 1999 gtp 3.8 sc p0305 #5 misfire
    St. Louis
    What kind of plugs did you install, and what gap? Running stock coil packs?
  4. #4 Re: 1999 gtp 3.8 sc p0305 #5 misfire
    Sep 2012
    United States
    ac iridium plugs stock coil packs....this car is in complete original state.
  1. Cylinder 5 misfire trouble code P0305
    By michellebuck76 in forum General Tech Discussion
    Last Post: 04-11-2013, 06:02 PM
  2. p0101, p0205, p0305?
    By Knightmare in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-10-2011, 11:08 PM
  3. Cylinder #3 misfire on 1999 Grand Prix GT
    By protoplayer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-12-2011, 09:11 PM
  4. 1999 GTP 3.8L SC Cylinder Misfire SES Light Flashing
    By pc305577 in forum Introductions/Noob Questions
    Last Post: 08-18-2009, 07:46 PM
  5. P0305 and P0401 96 3.1L Fixed
    By alacran in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-13-2008, 08:49 PM
