When I start my car I see smoke, and I look it my valve cover is leaking did GM have a recall on this, I don't wanna phone in and look like a knob. - Thanks - Mel
Only the GTP model had a recall for the valve cover and I believe it was for the front or rear only.
I would clean the oil up asap if its smoking and then replace the valve cover gaskets, your car is at risk of starting on fire.
Yes GM had a recall on this issue.
They will fix it for you as long as your vin comes up in the system as one of the affected models. Call your local dealership and find out.
Like all said it is the front valve cover gasket and grommets they also replace the front wire holder with reg wireholders to keep the wires away from the manifolds and oil
