Thread: Am I missing anything on this cam install shopping list?
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: Am I missing anything on this cam install shopping list?
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    I think I will end up going with the XPZ with 150# and a new stock chain from GM and new GM Lifters... just not sure which lifters, I don't know if you can throw in LS7 lifters which would be ideal. I hear and read many band things about comp lifters.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  2. #22 Re: Am I missing anything on this cam install shopping list?
    150's and an XPZ are gonna obliterate that stock chain.
    Just run an XP or S1X with 105's.
    Seriously.
    Hell, even Trannyman Dave and Reptile ran 130's with a stock chain. It's doable. Just don't go dropping the idle low or shifting super dumb high.
  3. #23 Re: Am I missing anything on this cam install shopping list?
    BillBoost ran S1X, 130#, 1.8 rockers on top with a JP single. If I were doing it over..I'd go stock or double roller. If you go double roller, read up as to why they snap (deflection) and you'll see how to fix it with chamfer before you install.
  4. #24 Re: Am I missing anything on this cam install shopping list?
    Apr 2012
    Middletown DE
    That was in the Bonnie right? what about 1.7 rockers? I have the s1x and 1.7's sitting in my basement both used with 16k on them. I currently have 105# on the heads.
    1993 Oldmobile 88
  5. #25 Re: Am I missing anything on this cam install shopping list?
    You need ported heads with the guides clearanced. 1.7's can go on top. Heck..if 1.8's work..1.7's will too.
  6. #26 Re: Am I missing anything on this cam install shopping list?
    Ported heads are boss.
  7. #27 Re: Am I missing anything on this cam install shopping list?
    Apr 2012
    Middletown DE
    So I got all this fun stuff.. Did I miss anything? I might install a Meth kit after I do a little more trans work. I was think of buying a trans core and building my own trans with the TEP stage 2 kit.
    3.2 pulley
    Intense racing stage 2 blower cam
    60# injectors.
    AEM WB,
    Trans PCS and frictions/steels
    Cam Bolt
    Timing cover gasket
    LIM gaskets
    Timing Chain
    (not pictured TEP shift kit)
    Reading around the trans threads.. do i need this for my 2005 GT?
    http://shop.tripleedgeperformance.com/4T65E-Hardened-4th-Clutch-Shaft-84860C.htm
    1993 Oldmobile 88
  8. #28 Re: Am I missing anything on this cam install shopping list?
    Eww, stage 2 cam.
  9. #29 Re: Am I missing anything on this cam install shopping list?
    Apr 2012
    Middletown DE
    Quote Originally Posted by blueguy91 View Post
    Eww, stage 2 cam.
    Meh, bills bonnerville had the s1x I figured the s2x will be just fine. It sounds pretty good too and after researching makes the same or more number then the XP Cam
    INTENSE-Racing.com: INTENSEā„¢ Supercharged/Blower 3800 Camshafts
    1993 Oldmobile 88
  10. #30 Re: Am I missing anything on this cam install shopping list?
    You missed coolant elbows, and if that's a double roller, make damn sure you fix the chamfer and consider a milled pump cover.
    You don't need a hardened 4th shaft. 2005 has the new part in it.
  11. #31 Re: Am I missing anything on this cam install shopping list?
    Apr 2012
    Middletown DE
    Got the elbows, I ordered the SS set and its a single.
    1993 Oldmobile 88
  1. Tranny shopping List
    By MrPoopyButthole in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-14-2012, 11:48 AM
  2. Top Swap Shopping List and a question
    By acidcrashdburnd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2012, 12:28 PM
  3. LIM Shopping List
    By fri3dchick3n in forum General Tech Discussion
    Last Post: 04-18-2011, 12:10 PM
  4. Prioritizing Parts Shopping List
    By brandonl2000 in forum General Tech Discussion
    Last Post: 01-16-2011, 11:27 PM
  5. My Shopping List
    By ZR1Vette09 in forum General Tech Discussion
    Last Post: 03-17-2010, 11:04 PM
