Thread: Changed Spark Plugs, Now I have codes. Please help
Results 1 to 19 of 19
  1. #1 Changed Spark Plugs, Now I have codes. Please help
    SE Level Member GTPJason's Avatar
    Sep 2012
    New Carlisle, OH
    I changed spark plugs last night. On the way to work this morning, it ran like crap after it warmed up. Crappy MPG too.
    Codes are:
    P0300 (multiple misfire)
    P0131 (O2 Sensor Bank 1 sensor 1
    P0137 (circuit condition O2 Sensor bank 1 sensor 2)
    P0171 (fuel trim bank one condition)
    I pulled the engine forward to get to the rear plugs. Is there something that is commonly disconnected whild doing this. I've check all the vacuum lines around the s/c and all seem okay.
    Any Ideas?
    2000 Pontiac Grand Prix GTP: Black on Black, all stock
    1987 Buick Grand National: 3.8L stock block, Billet Main Caps/ARP studs, GT6776E, 3400 Stall, 55lb injectors, LT1 MAF-Translator, Turbo Tweak chip: 516 FT-LB torque, 16# boost-93 oct
  2. #2 Re: Changed Spark Plugs, Now I have codes. Please help
    Bad o2...vacuum leak...random misfire...did you blow it up?
  3. #3 Re: Changed Spark Plugs, Now I have codes. Please help
    Sep 2012
    New Carlisle, OH
    Quote Originally Posted by blueguy91 View Post
    LOL nope... Oil looks good. Coolant still full. No engine noises. After it warms up it starts acting like it's running out of fuel.
  4. #4 Re: Changed Spark Plugs, Now I have codes. Please help
    Did you click the wires on all the way? Did you do them one at a time or all at once? You may have crossed a few wires.
  5. #5 Re: Changed Spark Plugs, Now I have codes. Please help
    It goes on the coils...top to bottom...
    6
    and if you're standing in front of the motor...
    2 4 6
    Blower
    1 3 5
  6. #6 Re: Changed Spark Plugs, Now I have codes. Please help
    Sep 2012
    New Carlisle, OH
    I did them one at a time. It runs great until it gets warm. NO misses at cold idle.
  7. #7 Re: Changed Spark Plugs, Now I have codes. Please help
    Sep 2012
    New Carlisle, OH
    6
    2 4 6
    Blower
    1 3 5
    Thank You! very helpful guys.
    I'm thinking maybe I pulled the vacuum line off of the EVAP canister when I rolled the motor forward...
  8. #8 Re: Changed Spark Plugs, Now I have codes. Please help
    Whelp, that'd probably do it.
    That's for a Bonne' but it's close enough minus our EVAP goes towards the back at the firewall.
  9. #9 Re: Changed Spark Plugs, Now I have codes. Please help
    Sep 2012
    New Carlisle, OH
    I'm about to go out and look. I'll update when I find out!
    Thanks all!
    Sep 2012
    New Carlisle, OH
    Found nothing disconnected. It has ran flawless for 30 miles now.
    Sent from my DROID RAZR using Tapatalk 2
  11. #11 Re: Changed Spark Plugs, Now I have codes. Please help
    Did you buy crappy plugs?
    Sep 2012
    New Carlisle, OH
    AutoLite 606 copper cores
  13. #13 Re: Changed Spark Plugs, Now I have codes. Please help
    Did you gap them?
  14. #14 Re: Changed Spark Plugs, Now I have codes. Please help
    And if you did what did you gap them too?
    Sep 2012
    New Carlisle, OH
    Yes. .060"
    Sep 2012
    New Carlisle, OH
    Fuel pump was bad. It totally stopped running on me. New pump, all good. Going to do the fuel filter tomorrow. Ohm the injectors and do a compression check just to be sure nothing else is going on.
    Thanks for all the help!
  17. #17 Re: Changed Spark Plugs, Now I have codes. Please help
    Well that's random.
    Glad you got it fixed though.
    Run some seafoam through that b1tch next
  18. #18 Re: Changed Spark Plugs, Now I have codes. Please help
    Sep 2012
    New Carlisle, OH
    Car has been running good for a couple days now. I have a P0650 code (SES light) I'm assuming someone removed the bulb. Any tips on going in and replacing this?
  19. #19 Re: Changed Spark Plugs, Now I have codes. Please help
    I did the lim gasket on a girls malibu once and it would randomly not start. Fuel pump went bad sometime while i was working on it apparently. Quite random but easily fixable.
  1. Changed plugs now runs like .....
    By toolmanz in forum 5.3L V8 (LS4)
    Last Post: 07-27-2012, 07:27 AM
  2. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  3. Changed o2 sensor and Still throwing out same codes!?????
    By johnnyb in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-18-2011, 04:16 PM
  4. Just changed the plugs on the Comp G.
    By speedy2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-19-2011, 03:49 PM
  5. Changed plugs and now misfiring
    By dieselden in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2011, 11:56 AM
