My m90 has some play when i turn the pulley back in fourth like i can the rotters dont wanna stop spinning. How can i fix this or is the supercharger no good?
If you hold the rotors there is some play in the snout? Likely the coupler is bad
the snout will always have a slight, tiny amount of play when spinning the pulley.
and the rotors are heavy, they like to keep going when you spin them. it's called inertia.
Gears worn?
Likely the coupler is shot, tends to go out.
Simple search on how to replace will get you a write-up
INTENSE-Racing.com: INTENSE Supercharger Coupler Change Kit
Kit includes everything you need to replace it. ^^^
