Thread: zzps xpz cam
Page 3 of 3 FirstFirst 123
Results 41 to 42 of 42
  1. #41 Re: zzps xpz cam
    Jan 2012
    Pennsylvania
    There isnot a big lobe at idle with this cam. I'm not sure what the idle is suppose to be but I am running at around 750rpm after warm up and she want's to stall every now and then when I come to a stop. I'm thinking of bumping it up another 50 rpm or so at idle after warm up. Also start up requires just abit more cranking then a stock cam. So far I really like this cam but only time will tell if it's worth it. BTW you guys with 04s+ is there a good high flow fuel filters for our cars?
  2. #42 Re: zzps xpz cam
    Sep 2012
    mn
    subscribed. keep an update about this xpz cam. i have it selected for part two of my build.
    1994 Oldsmobile Cutlass Supreme
    Coil-overs: GR2; F:400, R:350 Gen 2 lateral arms w/Poly L67 swap: Gen 5 S/C I/C N* 3" DP Wbodystore Custom PCM tune 104's 160T Gen 2 A/C
  1. XPZ SETUP....and zzps thoughts
    By shawn in forum General Tech Discussion
    Last Post: 07-30-2010, 05:19 PM
