Thread: RPMs bouncing when cruising
Results 1 to 5 of 5
  1. #1 RPMs bouncing when cruising
    SE Level Member nukkinfuttz's Avatar
    Sep 2012
    Richmond Va
    Im driving along on flat level interstate at and the RPMs will sometimes start boucning like 100-200 RPMs on the needle. I also feel it in the seat. Its a very rythmic pulsation, like a sine wave or something. I give it some gas, and it may clear and not come back, or it might return. If i take no other actions and just hold steady it will also clear itself up after a short period of time. It comes and goes throughout my entire trip. Its just one of those things that is annoying. Has anyone solved this problem before? what was it?
    Thanks
    91BerettaGTZTurbo=Holset HX-35,26PSI,Bored,EagleRods,WisecoPistons,O-rigned,TitanCopperHG, adj Cam Gears,Custom turbo mani,TurboSmart36mmWG,Screamer Pipe,Custom 3"turboback,MSII-E, LC1Wideband, PyroMeter,KnockSense,Walbro 255LPH,75lbs/hr inj's,3"Core42"Wx15"T IC,HKS BOV Waterinjection,antilag,6puckClutch,Slicks, just needed a Part Number
  2. #2 Re: RPMs bouncing when cruising
    TCC issue possibly.
  3. #3 Re: RPMs bouncing when cruising
    200+ K trans with unknown history that "needed" a new filter and lucas trans additive to move?
    Yeah, I'd say it has untold issues everywhere.
    From the probable stripped fourth gear splines to the possible clogged TCC solenoid.
  4. #4 Re: RPMs bouncing when cruising
    Kansas
    TCC would be my guess as well. If it were 04+ it could be the accelerator pedal.... but not in your case.
  5. #5 Re: RPMs bouncing when cruising
    Often this is ignition related. Might even be a dirty maf sensor. If your plugs/wires aren't current.. do them. Clean the TB and maf.
  1. rpms bouncing while driving between 2nd and 3rd
    By RyanL in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-05-2012, 02:57 AM
  2. rpms bouncing around weird
    By gtcoup in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-23-2011, 10:46 PM
  3. bouncing Rpms, then stalls."update with Fix"
    By thedudeSE in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-23-2011, 06:11 PM
  4. kr at cruising???
    By orange97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2009, 10:20 AM
  5. Few kills just cruising around..
    By Bogers99GTP in forum Track Sessions and Kills
    Last Post: 11-02-2008, 10:20 PM
