Thread: cutting out under load and boost!!
Results 1 to 11 of 11
  1. #1 cutting out under load and boost!!
    Aug 2012
    Cushing, OK
    car wouldn't start so i replaced the fuel pump and put more fuel in it and it runs good at idle. when i would hammer on it in neutral as soon as boost tried to build it would start cutting out and falling on its face.. so i found a vacuum hose disconnected put it back and now it only cuts out under load when the boost starts to build please help.. changed fuel filter right before the old fuel pump went out
  2. #2 Re: cutting out under load and boost!!
    The Boss Iceman6669's Avatar
    Jun 2011
    Well, if it is only doing it UNDER LOAD, I would suggest checking the CAT. BUT if it is only doing it under BOOST AND LOAD, it might be a different problem.
    2011 F-150 Yote powered
  3. #3 Re: cutting out under load and boost!!
    Aug 2012
    Cushing, OK
    its a 99 gtp and the cat is gone.. could the fuel filter be plugged up again already?? and also are there any fuses or sensors or anything.. I'm so lost on this I'm a diesel guy lol
  4. #4 Re: cutting out under load and boost!!
    Jun 2011
    maybe a Cam sensor. OR bad ICM.
  5. #5 Re: cutting out under load and boost!!
    Feb 2009
    flintnasty MI
    Quote Originally Posted by Iceman6669 View Post
    lol, neither of those would cause issues.
    Check your plugs/wires/coils.
  6. #6 Re: cutting out under load and boost!!
    Jun 2011
    Really.... It is ok to have a bad Cam sensor and/or a bad ICM?
  7. #7 Re: cutting out under load and boost!!
    Kansas
    Quote Originally Posted by Blowblackorgetback View Post
    Problem found. Whose cool... he's cool.
  8. #8 Re: cutting out under load and boost!!
    Aug 2012
    Cushing, OK
    hey I'm not saying i was doing it to be cool i was just seeing if i could get it to cut out before i wasted my time to go drive it.. thanks to you other guys though.. and this all happen in one night keep in mind i parked it running just fine went out the next morning and bam wouldn't start and when i finally got it running after the new pump still running like crap... btw it rained the night all this happen I'm not sure if there was lightening or not if that would even make a difference also the plugs and wires are new
  9. #9 Re: cutting out under load and boost!!
    You sure you arent just bouncing off the rev limiter?
  10. #10 Re: cutting out under load and boost!!
    X2 these cars have 4,000 rpm rev limiter in park and neutral.
  11. #11 Re: cutting out under load and boost!!
    Aug 2012
    Cushing, OK
    Like I said it was doing it in neutral way before limiter and I got it fixed now it just goes to the limiter.. However under load it runs like total crap that's what I'm trying to figure out
  1. 3.8 n/a running hot and cutting off
    By GTPSHAWTY in forum General Tech Discussion
    Last Post: 12-05-2011, 12:52 PM
  2. cutting out under a load
    By re209 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2011, 02:02 PM
  3. radio cutting out
    By gtcoup in forum Off Topic Discussion
    Last Post: 12-26-2010, 01:25 AM
  4. ses codes and car cutting out
    By Xhondaguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2008, 12:33 PM
  5. Car Cutting out
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-31-2008, 04:48 PM
