Thread: how to properly measure a sc pulley
Results 1 to 12 of 12
  1. #1 how to properly measure a sc pulley
    SE Level Member eddie97gt's Avatar
    Feb 2009
    roanoke va
    Supercharger pulley measures 3.1 at bottom of groves , any input here would be appreciated
  2. #2 Re: how to properly measure a sc pulley
    Pics of pulley?
    Using a ruler or tape measure is really all you need.
  3. #3 Re: how to properly measure a sc pulley
    The Boss Iceman6669's Avatar
    Jun 2011
    Arent like almost ALL aftermarket pullies Labeled??
    2011 F-150 Yote powered
  4. #4 Re: how to properly measure a sc pulley
    My 3.4 has no markings on it
  5. #5 Re: how to properly measure a sc pulley
    Feb 2009
    roanoke va
    Used a set of dial calipers, going back over to the garage today to work on my engine , ill look harder see if there is any numbers , I do know this , much smaller looking than stock
  6. #6 Re: how to properly measure a sc pulley
    Do you have other mods? Or just the pulley?
  7. #7 Re: how to properly measure a sc pulley
    Feb 2009
    roanoke va
    It has a set of diamond pistons , headers , gonna put colder plugs in it , and a fender cold air intake , motor is tore down to the short block , think the ecu has been tuned also , stock cam , and I'm gonna port the heads a little bit , run a 160 stat
  8. #8 Re: how to properly measure a sc pulley
    Sounds like you have no real clue on whats done to it and what you need to do.
  9. #9 Re: how to properly measure a sc pulley
    Diamond pistons - waste
    Boring block - waste
    160* - waste
    stock cam with ported heads - waste
    not knowing if it is tuned or not - more of a problem.
    My suggestion. Go get the PO and find out is going on 110%.
    Then, go buy a stock short block, stud the heads, re-gasket and get new fluids, port the heads, run a cam of some sort because porting the heads with a stock valvetrain would be a waste. Start off with a 3.4" pulley and go from there when you have a way to tune it, because a 3.1" will be too small. Probably running the factory injectors static as well which is no bueno.
    So yea
  10. #10 Re: how to properly measure a sc pulley
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Rebuilding the bottom end = fail 90% of the time.
    GPONA #1 Cyber Bully
  11. #11 Re: how to properly measure a sc pulley
    Quote Originally Posted by blackspike2710 View Post
    Only if you don't know the correct steps.
    People just slap it in and the reason they don't stay together is because 100% of those 90% don't line bore the mains...which kills the rebuild...making it a 50 mile winner.
  12. #12 Re: how to properly measure a sc pulley
    Feb 2009
    roanoke va
    Well engine was gone through about 35k ago , I just opened up to check the mains and rods , make sure they was ok , no abnormal wear or anything like that . I am a tad old school , built a few engines in the past , mostly Chevy 350 . Just didn't want to get this engine in the car and have a knock or something internal wrong ya know . Gonna put new gaskets , plugs and what nots , tore heads down last night , gonna take off the casting flash in the runners and blend the bowls . But the engine has has the headers , pulley , and pistons in it for 3 years or so and everything inside looks to be in good shape
  1. INFORMATION How to properly wash/wax your car.
    By Timing in forum Detailing Tips and Tricks
    Last Post: 04-22-2013, 07:28 AM
  2. Investing properly
    Last Post: 08-11-2011, 03:52 PM
  3. sunroof not working properly
    By BoostnBlackGTP in forum General Tech Discussion
    Last Post: 02-20-2011, 06:39 PM
  4. Heater not working properly
    By dms13 in forum General Tech Discussion
    Last Post: 12-13-2010, 07:16 AM
  5. How to measure supercharger pulley size..
    By the1euge in forum General Tech Discussion
    Last Post: 09-12-2008, 06:05 PM
