Thread: 105# springs vs. ls6 springs
Results 1 to 6 of 6
  1. #1 105# springs vs. ls6 springs
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    so way back when, when i was rebuilding the motor installed 105# springs ls1 retainers intense pushrods all the jazz to support hs 1.9s. but would installing the yellow ls6 springs would of been better than 105#. im not intending on changing im just looking and to further my knowledge and fully understand.
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  2. #2 Re: 105# springs vs. ls6 springs
    LS6 is lower seat pressure but higher spring rate, so more wear on tensioner, yet similar control of valves. At least in the world of rockers.
  3. #3 Re: 105# springs vs. ls6 springs
    so the 105 is essentially better
    SMGPFC #77
  4. #4 Re: 105# springs vs. ls6 springs
    yeah, costs more though.
  5. #5 Re: 105# springs vs. ls6 springs
    Feb 2009
    flintnasty MI
    stock springs will work good enough with rockers. Harland sharps will still float and otherwise not increase your horsepower anyway.
  6. #6 Re: 105# springs vs. ls6 springs
    thats interesting though cuz there a huge differnece in power from the stock rockers to the hs i also got comp cam lifters
    SMGPFC #77
  1. DNA springs... yep i said it
    By OmegaRed in forum Brakes/Suspension/Chassis
    Last Post: 01-25-2015, 08:08 PM
  2. SSC springs
    By tod1d in forum Brakes/Suspension/Chassis
    Last Post: 09-06-2011, 06:53 AM
