Thread: Replacing a push rod
Results 1 to 8 of 8
  1. #1 Replacing a push rod
    Aug 2012
    Richland oregon
    I am replacing one push rod, do I have to replace the bolt also, I've heard this is a stretch bolt
  2. #2 Re: Replacing a push rod
    Cambridge, Ontario Canada
    yes
    2005 E55 - stock
  3. #3 Re: Replacing a push rod
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Why are you replacing the pushrod? Pushrods on these cars don't go out unless something underneath it is causing it.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  4. #4 Re: Replacing a push rod
    many of us have reused the rocker bolts. dont force yourself to buy a set for one. just lock-tite it.
  5. #5 Re: Replacing a push rod
    You can buy the bolts individually from your local dealer if you're really worried about it.
    It's a few bucks.
  6. #6 Re: Replacing a push rod
    Aug 2012
    Richland oregon
    The engine had a top end noise while on a long trip, I kept driving, when I pulled the valve cover I foung the push rod broken in two however held together.
  7. #7 Re: Replacing a push rod
    That's always good lol
  8. #8 Re: Replacing a push rod
    Jun 2012
    Port Huron,Michigan
    yes
  1. push button start
    By z3r0 in forum Visual/Body Modifications
    Last Post: 06-01-2011, 11:09 AM
  2. Pull not push...
    Last Post: 05-27-2011, 02:22 AM
  3. push button ideas
    By BoostJunki3 in forum Audio, Security & Visual Electronics
    Last Post: 05-14-2011, 08:48 PM
  4. Push button Start
    By crock in forum General Tech Discussion
    Last Post: 08-31-2010, 04:41 PM
  5. Push Bumper
    By bigboibbp in forum Visual/Body Modifications
    Last Post: 06-20-2010, 07:08 PM
