Thread: 3.4 pulley squeak
Results 1 to 7 of 7
  1. #1 3.4 pulley squeak
    Gainesville, Fl
    I recently put my 3.4 pully on and it sometimes squeaks on start up? This normal? The squeak goes away but I was just wondering.
    I also have zzp downpipe w/cat into 2.5in no res and 2 magnaflow mufflers. And a KN&N cai. Thing im getting next is the overkill pcm, which I hope will make a difference. First Post so Hi.
  2. #2 Re: 3.4 pulley squeak
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    could it just be your belt squeaking?
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  3. #3 Re: 3.4 pulley squeak
    Banned
    Wichita Falls, Texas
    Sounds like the belt squeaking to me. Make sure it's on right to begin with.
  4. #4 Re: 3.4 pulley squeak
    GT Level Member Preotic's Avatar
    Missoula, MT
    it could be the alignment of the pulley you just put on.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  5. #5 Re: 3.4 pulley squeak
    Banned
    oswego
    did you put a new belt on the car when you changed the pulley? Probably not, doesn't have to be smaller but it does have to not be worn out...
  6. #6 Re: 3.4 pulley squeak
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    How long does it squeak for? And are you sure it is the S/C or around that area that is squeaking?
    2006 Grand Prix GXP
  7. #7 Re: 3.4 pulley squeak
    Gainesville, Fl
    Sorry i dont have acess to much where im at to reply, but the squeak goes away in a min and it only squeaks on start up once in a while.
    i did put a new belt on it, so thanks for your responses.
  1. 3.5 SC pulley on 07 GP/GT
    By 07 GPGT in forum General Tech Discussion
    Last Post: 03-27-2009, 11:23 PM
  2. 07 gp/gt 3.5 pulley
    By 07 GPGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-21-2008, 03:57 PM
