Any KR is bad KR.
I wouldn't be happy with 2* @ WOT.
Any KR is bad KR.
Try it and let us know when it goes BOOM and let us kno we were right. Any knock is to bad knock. At least go with headers and scan!
A stock 97-03 GTP has 5* of KR at WOT and it never hurt my car before
hmmmm did not know that, but your saying on a 3.4'' pulley 2* on KR at the shifts is bad?....like potentially chipping a piston bad?
detonation will wear down the piston, and weaken it over time.
Eventually it will fail.
The more power you make, the more accelerated the process.
hmmmm so what do you guys think i should do, put on the 3.4'' and if theres kr drop back to a 3.6''?
not going to sink that kind of dough into my DD
Pontiac Performance Racing Products for International Sales from SSAutochrome Inc.
Price - $175 + 50.00 shipping...
Side Note - more needed for the Copper RTV, and the good Clamps but that is like +/- $25.00
You won't drop that kind of dough into your DD but you spent money on the ZZP STB, the GMPP Sways, a 3" DP & Cat-Back, and 12" Brake upgrade... not to mention the Built Trans in your sig.... I'd love an explanation.
Cheap, Fast, Reliable. Pick two.
brakes cost me less then new pads and rotors
old trans blew up
front sway bar broke rear was free when i bought the front
old cat back was rusted to pieces and every shop wanted $600 for a stock replacement
zzp stb wasnt the best purches but oh well
lol @ thinking headers are expensive.
You don't want to blow up the car then pulley up.
Or get a good tune, a canned PCM on a pullied car that is getting old isn't going to be knock free like they were able to 15~ years ago.
IDK, last set of headers I put on...I didn't get a happy ending.
alright i wont run a 3.4" its probably a bad idea ill stick with a 3.6"
You just need to get a custom tune...and skip the lame DP crap, because the second most restrictive part of the car is in the manifolds...its an awful factory design anyways...I'm sure if we were able to run a setup similar to what Vogel did back in the day with 2" primary long tubes that ran under the oil pan and had a "B-Pipe" like the VQ FWD Maxima's for example...mind you that was nearly an 11 second rocker car as well. You get someone that can tune well, that 3.4" should be fine with headers as long as everything else is in good shape.
Touche, bugeyes.
Ha.
