Thread: Intercooler fluid temps
Results 1 to 20 of 23
  1. #1 Intercooler fluid temps
    Looking for inlet and outlet fluid temps.
    Curious if anyone really sees a large spread between the two temps.
  2. #2 Re: Intercooler fluid temps
    Grand Island, Nebraska
    What are you up to now matt....?
  3. #3 Re: Intercooler fluid temps
    Dec 2008
    Canada
    I actually just installed this gauge this week:
    52mm Dual Air Intake Intercooler Temperature Gauge Meter Blue Digital LED SMOKE | eBay
    I put a water temp sensor on both the inlet and outlet of the intercooler. The gauge actually comes with two air temp sensors but water temp sensors will work as well. I'm planning on hooking up the air temp sensors (supercharger air outlet temp, and intercooler air outlet temp), I'm just waiting for the 4pt2 switch I ordered to swap instantaneously between the sensor inputs. I think I'll just tap the supercharger outlet for a vacuum line and t the air temp sensor into it and for the outlet temp I'll just t into the LIM vacuum line.
    My cars actually not drivable right now, so I can't tell you what it reads when driving. But at cold idle there's around a 2-3 Celcius difference in the inlet and outlet temps.
    Mike
  4. #4 Re: Intercooler fluid temps
    Initial (incorrect) calculations suggested water doesn't matter, its all about getting as much heat into the water as possible.
    Once I found some mistakes in conversions, it seems water quantity and temperature does matter.
    Essentially stemmed from "Why does thrasher/PRJ seem to hold a marginal benefit over ZZP?"
    Namely bar/plate vs heater core. Seems a bar and plate would be ideal if it could be impossibly large, but we simply do not have the space.
    Laminova cores come to mind, but those are precision pieces and quite pricey.
    All leads back to my original assumption: Buy a neil core, cheap front mount, bosch pump (possibly meziere), and large reservoir in trunk. Tank being optional as well.
  5. #5 Re: Intercooler fluid temps
    Florida
    so it was never said.... how hot/ what temp is the water coming out of the IC?
  6. #6 Re: Intercooler fluid temps
    Dec 2008
    Canada
    Like on of these?
    I made that one and have been using it for the at least the past 2 years without incident. It seems to work much better than any heater core intercooler I've used before. I made a build thread on clubgp when I did the project.
    Mike
  7. #7 Re: Intercooler fluid temps
    Thats pretty cool.
    GT Level Member shawnschuldt's Avatar
    Jun 2010
    Beloit, WI
    [QUOTE=97Coupe;864278]
    Like on of these?
    Mike
    You wouldnt have a link to that build log anymore would you?
    Sent from my SCH-R760 using Tapatalk 2
    --00 Red GTP--
    CAR:E85--3.25"--SSAC Headers--ported gen 3--1.9 Rockers--AL 104's--65# Injectors--Zez wet kit 55 shot--9" AEM Cone--HP Tuned by me--No Cat--AEM
    13.07@108mph
  9. #9 Re: Intercooler fluid temps
    never seen a core that looks remotely like that... how does it work?
    Did you stick to the recommended 15* inlet/outlet?
    Happen to have a link to your build thread?
    Quote Originally Posted by gtpsleeper View Post
    Google the name. Company's site will explain. Used in cobalt/vette/zr1/cts-v etc.
  12. #12 Re: Intercooler fluid temps
    Minnesota
    I don't know about that design of that core but if it works it works.
  13. #13 Re: Intercooler fluid temps
    its advertised as more efficient but is it really THAT much better? anyone ever tested one?
  14. #14 Re: Intercooler fluid temps
    Dec 2008
    Canada
    ClubGP Message Forum troubleshooting
    That link should go to my build thread. I went with the recommended 15mm slots which seems to work best for these cores.
    I can't actually drive my car right now, I sent my zzp control arms back for their updated versions, so when I get them back in a few weeks I should be to see the real time input/ output temperatures on the gauge.
  15. #15 Re: Intercooler fluid temps
    They should have just sent you new front heim joints, not required the entire LCA to be sent back.
  16. #16 Re: Intercooler fluid temps
    Dec 2008
    Canada
    They have a newer stronger design out for them and they're offering to swap them for free so I figured why not. This is from their website:
    Anybody that has purchased a set of our tubular control arms for either the 3800 or Ecotec platform can send them in to us for an exchange for our new improved arms free of charge!!! Our new arms are a larger diameter, and heavier gauge tubing, and have a new stronger design
    **please email Steve@ZZPerformance.com for a return authorization #
    **all returns must be done in the next 90 days
    **customer is responsible for shipping cost to ZZP...we will pay return shipping
    August 8 at 11:43am
  17. #17 Re: Intercooler fluid temps
    Thats even better!
    Always wanted a set, but my car is 100% daily, so deadly LCAs isn't an option.
  18. #18 Re: Intercooler fluid temps
    x2 matt.... id have to see the new ones though...
  19. #19 Re: Intercooler fluid temps
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    Quote Originally Posted by 97Coupe View Post
    Like on of these?
    Mike
    Looks like a huge flow restricion to me . I guess I'd have to see a view through the top.
    Not bashing, just very different from what I've seen before.
    Edit: just looked at your post on club GP. Nice work OP, I'm still saying it looks too restrictive to flow though.
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  20. #20 Re: Intercooler fluid temps
    3 to one is easy, use two Y blocks or one 3-1 block.
    Its interesting you mention air flow, this is the only intercooler core GM uses.
  1. what are your temps?
    By rell2005 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-24-2012, 06:26 AM
  2. crazy high trans temps or no temps!? pics!
    By blknbstd in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-20-2011, 06:07 AM
  3. intercooler temps
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2011, 04:49 PM
  4. My car temps?
    By getsumbaby in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2008, 03:36 PM
  5. Intercooler Fluid Additives?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 04-23-2008, 10:56 AM
