Thread: 97 gtp multiple cylinder misfire help.
Results 1 to 11 of 11
  1. #1 97 gtp multiple cylinder misfire help.
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    i have 97 gtp and i have been getting this code ever since i had the car. i have replaced the plugs with autolite 606's gapped at .060 replaced the wired and the coils and got a new icm but didn't need it because mine if fine. i recently cleaned my throttle body and part of the inlet of the supercharger where the throttle body bolts up. I haven't changed the o2 sensor. and my car drives fine it doesnt stutter or anything like that while driving but at idle my engine is kinda jumpy it moves alot at idle and seems kinda ruff the rpm's are steady at around 700 and ever since i cleaned the throttle body the code takes longer to pop back up. im thinking its my o2 sensor and i might even get a new icm to see if it changes again.
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: 97 gtp multiple cylinder misfire help.
    St. Louis
    Have you checked for vacuum leaks? Start at the "T" under the snout and go from there. Any mods done to it or are you stock?
  3. #3 Re: 97 gtp multiple cylinder misfire help.
    Sep 2011
    palm harbor florida
    the vaccum peice under my snout isint a t its and L shape. and all i have is an intake
  4. #4 Re: 97 gtp multiple cylinder misfire help.
    It's possibly a cam position sensor. But i'm just kinda throwing that out there as that's what my wife's 3.4 ga gt did when hers went bad.
  5. #5 Re: 97 gtp multiple cylinder misfire help.
    Sep 2011
    palm harbor florida
    ok a little update for the code i was just driving normally and the ses light went off by its self and then he next time i drove my car again it came on after about 5 miles. and not it keeps doing that? its confusing the hell out of me. does anyone have any ideas?
  6. #6 Re: 97 gtp multiple cylinder misfire help.
    Apr 2009
    Fort Worth TX
    Is the fuel pump original?
  7. #7 Re: 97 gtp multiple cylinder misfire help.
    Check all your grounds and if possible scan and see which cylinders are misfiring and when.
  8. #8 Re: 97 gtp multiple cylinder misfire help.
    Sep 2011
    palm harbor florida
    the fuel pump is original. everytime i scan my car its p0300 which is multiple random cylinder misfire. i have no idea which ones do it the most if any.
  9. #9 Re: 97 gtp multiple cylinder misfire help.
    Are you scanning with a hand held scanner or do you have an aeroforce or scangauge or torque?
  10. #10 Re: 97 gtp multiple cylinder misfire help.
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    Mayb try n gap your plugs to .55, Then c if u still get mrcm? And when is this happening, idle or wot?
  11. #11 Re: 97 gtp multiple cylinder misfire help.
    Sep 2011
    palm harbor florida
    im using a hanheld obdII scanner with live data. i dont knw when this happens because sometime it will just start flashing idle or not
  1. ses light for multiple cylinder misfire help!!!
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-20-2012, 09:17 AM
  2. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  3. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  4. Random multiple cylinder misfire
    By sunfiregtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2009, 08:58 PM
  5. P0300 multiple cylinder misfire code
    By Reeddawgy in forum PCM Tuning
    Last Post: 07-15-2008, 07:42 PM
