Thread: XPZ Cam 130 lb spring longevity as daily?
Results 1 to 18 of 18
  1. #1 XPZ Cam 130 lb spring longevity as daily?
    GT Level Member RegalGS98s's Avatar
    NJ
    I have a XPZ Cam with the 3/8 pushrods I'm going to run in my 98 Regal. Currently my heads have 90lb LS6 springs on heads I ported. Will the 90lb springs work at all without destroying something and just give me a performance loss or are the 130lb springs required? If I run the 130lb springs, how long should I expect they'll last before having to replace them so I don't end up with a broken spring. The Regal will be daily driven. I'll also be using the stock rockers with the JP Performance Double Roller chain. If I need the 130lb springs, which brand should I get? I know there were some failures on one the brands 105 springs.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  2. #2 Re: XPZ Cam 130 lb spring longevity as daily?
    Ohio
    you need 130s for that cam.
    they'll last.
    get crow
  3. #3 Re: XPZ Cam 130 lb spring longevity as daily?
    NJ
    Do you know how long or many miles the crow cam 130 lbs have lasted in our cars? Anyone get 20k or 50k yet running them with an XPZ or similar cam?
  4. #4 Re: XPZ Cam 130 lb spring longevity as daily?
    Ohio
    dd'ing them. im not sure, if you arent always ragging on it, with the double roller im sure you could go 50k
  5. #5 Re: XPZ Cam 130 lb spring longevity as daily?
    I'm surprised no one suggested reading up on the JP failures. A couple years back it was an issue, not sure if it still is etc. May have been more the deflection of people not machining the crank gear..but there was talk about Jp vs rollmaster and definately ensure the crank gear is right.
    130# Crowe should be fine to daily. Doesn't the XPZ require different pushrods and Stage 3 heads for clearance?
  6. #6 Re: XPZ Cam 130 lb spring longevity as daily?
    Ohio
    he has the 3/8...OR option i have no clue on
  7. #7 Re: XPZ Cam 130 lb spring longevity as daily?
    I have those sitting in my garage on Bill Stewarts XPZ.
  8. #8 Re: XPZ Cam 130 lb spring longevity as daily?
    NJ
    The JP failures I read a while ago were 99% install error, but heard about the crank gear also. I think it was Blueguy91 that said it was mostly install errors. Somewhere on here I read the JP sets were supposed to have been fixed. I assume you mean the crank gear doesn't line up with the other gear so it had to be machined so the chain lines up?
    I have the 3/8 pushrods (six of each 7.05 and 7.10 I think). The heads they noted port and polished required. Not sure what you mean about clearance.
  9. #9 Re: XPZ Cam 130 lb spring longevity as daily?
    Ohio
    the chamfer on the gear needs machined to match that of the stock gear..nothing a minute on a lathe doesn't fix
  10. #10 Re: XPZ Cam 130 lb spring longevity as daily?
    Never Never Land
    My heads have 130lb crows. Previous owner said he's put 20K on them. I see no issues with them. He also had a cam a little bigger than the XPZ.
    And no go on the JP. Get a rollmaster
  11. #11 Re: XPZ Cam 130 lb spring longevity as daily?
    SE Level Member deangtp's Avatar
    Kansas City, MO
    IM Daily driving an XPZ/130 car. Only about 2k miles on it though. I had a JP with an XP cam and 105's. That thing stretched out big time. Im now rolling with a rollmaster.
  12. #12 Re: XPZ Cam 130 lb spring longevity as daily?
    Never Never Land
    Just an FYI too guys. When your rollmaster gets stretched, Cloyes makes a chain that works on the rollmaster gears. I forget the PN but I'll dig it up.
  13. #13 Re: XPZ Cam 130 lb spring longevity as daily?
    NJ
    Quote Originally Posted by deangtp View Post
    Was it a single or dual JP chain? How many miles did you have on it with the XP and 105's? Do you stomp on it often? And so, are you saying the JP chain itself is weaker than the rollmaster? There is a bit of price difference between the 2, but I assumed it was because of the past failures with the JP's they had to make themselves more attractive. I currently own a single rollmaster with about 5 minutes of run time and a brand new double JP.
  14. #14 Re: XPZ Cam 130 lb spring longevity as daily?
    Never Never Land
    The JP chains suck. They stretch fast and some have snapped
  15. #15 Re: XPZ Cam 130 lb spring longevity as daily?
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Basically what it comes down to is sell the jp if you can and go with a double roller i have a xpz build going and went with that you want to run as little of a risk as possible with any setup you build double roller is the way to go and with the springs 130 and crows like they stated above.
  16. #16 Re: XPZ Cam 130 lb spring longevity as daily?
    Feb 2009
    flintnasty MI
    The JP failures were due to the wrong gear being used for the wrong chain... they just did not mesh correctly and it was obvoius.... I have used the old JP chains without problems for tons of miles.
    A stock chain would be a fine choice behind the XPZ and 130s too... they are highly underrated for some reason.
  17. #17 Re: XPZ Cam 130 lb spring longevity as daily?
    NJ
    The JP failures were due to the wrong gear being used for the wrong chain... they just did not mesh correctly and it was obvoius.... I have used the old JP chains without problems for tons of miles. A stock chain would be a fine choice behind the XPZ and 130s too... they are highly underrated for some reason.
    Does the chamfer on the gear need to be machined to match that of the stock gear still then on the JP double set? I bought my JP double roller set at the beginning of this year so it's not that old. Still in the box. I've heard of people running the stock chain with 130s on here too. The JP Double should still be stronger and better than the stock though right? Think Blueguy91 on here said the Rollmaster failed on him so seems to be issues with both sets. Don't want to buy another set since I have the JP double, but will if I have to.
    GTX Level Member crbquist's Avatar
    Massachusetts
    I wouldn't trust a stock chain with that cam and 130s...
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  1. 1.9 Rockers longevity
    By MBruneaux in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-17-2012, 03:42 PM
  2. Daily Drivers?
    By Taz Magister in forum General Tech Discussion
    Last Post: 07-08-2011, 12:19 PM
  3. My daily conversation.
    By ZR1Vette09 in forum The Rant Forum
    Last Post: 03-21-2011, 10:03 PM
  4. Daily B!tch!ng : RANT AWAY!
    By singularity in forum The Rant Forum
    Last Post: 09-06-2009, 02:52 PM
  5. gs-t for a daily driver
    By turbotooslow in forum Off Topic Discussion
    Last Post: 10-04-2008, 04:11 AM
