Thread: Ported LIM & Ported SC vs Stock - GEN 3 gains?
Results 1 to 20 of 21
  1. #1 Ported LIM & Ported SC vs Stock - GEN 3 gains?
    Cambridge, Ontario Canada
    Motor swap has begun, hopefully a new thread and some pics as I progress through it. I am thinking of getting a WBS Ported Gen III SC & Ported LIM instead of using my stock stuff. Once the car gets fired back up again, mods will be as follows:
    Intake
    SD Headers
    1.84 YT Rockers
    Hopefully once tuned a 3.4 at least
    Would I see any benefit from going with the ported stuff aside from a hellacious blower whine?
    2005 E55 - stock
  2. #2 Re: Ported LIM & Ported SC vs Stock - GEN 3 gains?
    itll help, but itll never be a seat of the pants comparison.
  3. #3 Re: Ported LIM & Ported SC vs Stock - GEN 3 gains?
    You would be better off convincing me to sell you the Gen V/Lim sitting on my dead motor for a good price. Overall, you'd come out ahead on benefit for cost.
  4. #4 Re: Ported LIM & Ported SC vs Stock - GEN 3 gains?
    PM'd, convince me
    Plus even if I don't get a huge seat of the pants win just from the parts, will temps be reduced enough to come down to a 3.3 or something?
    2005 E55 - stock
  5. #5 Re: Ported LIM & Ported SC vs Stock - GEN 3 gains?
    Port your own blower and save money?
  6. #6 Re: Ported LIM & Ported SC vs Stock - GEN 3 gains?
    I did a little bit of SC porting with an die grinder and bit. I have no idea how some get so neat with the port job... the grinder wants to fly all over the place when putting pressure on it. Plus the WBS ported sc, comes with a ported LIM (which I would have no chance in doing). Gen V setups (complete with adapter) fetch a good buck still. At best I see this car doing low-mid 13's eventually
    2005 E55 - stock
  7. #7 Re: Ported LIM & Ported SC vs Stock - GEN 3 gains?
    GT Level Member fisher580's Avatar
    Jan 2012
    Dyersville, Iowa
    for me:
    CAI
    headers
    tune
    3.4
    i was getting 6-7 psi and topped the car at 139
    after porting the bottom and cleaning the SC and TB im getting 10-12 psi and pulling 145 (i just want a buck 50 lol)
    2001 Grand Prix GTP Coupe - Black-SOLD
    -SOLD
    2006 Grand Prix GXP - That Purplish dark red color
    -FWI, DiabloSport Trinity, and Trans. Cooler - - 6.8 @ 208 mph LOL
  8. #8 Re: Ported LIM & Ported SC vs Stock - GEN 3 gains?
    i now see where your posts are leading. you're THAT guy..
  9. #9 Re: Ported LIM & Ported SC vs Stock - GEN 3 gains?
    Quote Originally Posted by fisher580 View Post
    for me:
    CAI
    headers
    tune
    3.4
    I thought porting would make you move more air at a lower psi but same power through increased efficiency? Unless u got suspension and brakes no Gp should even entertain those speeds
    2005 E55 - stock
  10. #10 Re: Ported LIM & Ported SC vs Stock - GEN 3 gains?
    Quote Originally Posted by Elite6 View Post
    you are correct because you know slightly how thermodynamics work.
    he is incorrect and spewing laughter.
  11. #11 Re: Ported LIM & Ported SC vs Stock - GEN 3 gains?
    Do most people port with a die grinder by hand or use some kind of a drill press setup?
    2005 E55 - stock
  12. #12 Re: Ported LIM & Ported SC vs Stock - GEN 3 gains?
    I used my hand drill to p&p my sc
  13. #13 Re: Ported LIM & Ported SC vs Stock - GEN 3 gains?
    I used a die grinder with a $3 bit for metal cutting, worked great. Then I'm using sanding stones and such from my dremal to smooth the port out.
  14. #14 Re: Ported LIM & Ported SC vs Stock - GEN 3 gains?
    for me:
    CAI
    headers
    tune
    3.4
    This is full of pretty much nothing worthwhile.
    So you INCREASED outlet flow.
    But you also INCREASED your boost levels with the same pulley size.
    This is uber awesome, tell me how you defied the universe.
  15. #15 Re: Ported LIM & Ported SC vs Stock - GEN 3 gains?
    why are you porting your LIM? I mean sure less metal=less heat but unless youre going to IC you dont NEED to do that.... jw is all...
  16. #16 Re: Ported LIM & Ported SC vs Stock - GEN 3 gains?
    Thought less heat = less KR = smaller pulley in theory. I am hoping to get 1.84 YT's, SD headers, Intake & Tune to use a 3.3 - I think it will be close, just wondering if a ported LIM and SC will help me get there?
    2005 E55 - stock
  17. #17 Re: Ported LIM & Ported SC vs Stock - GEN 3 gains?
    SC yes but there wont be enough of a difference in the LIM. If you are doing it yourself, sure I would do it for the hell of it but Im just saying you would waste your money buying a ported LIM without the intention of going IC (unless you mean actually port matching it to the heads and not just cutting the top)...
  18. #18 Re: Ported LIM & Ported SC vs Stock - GEN 3 gains?
    What part of the LIM do you intend to port?
    The runners could be gasket matched, but they should only be matched to your heads.
    L36s could benefit from this without touching the heads as the casting was too small from the factory.
    The top of the LIM wont matter because the blower outlet is already matched to the LIM inlet.
  19. #19 Re: Ported LIM & Ported SC vs Stock - GEN 3 gains?
    So the stock L67 LIM is already big enough even if you port the stock L67 M90? Aside from the runners?
    2005 E55 - stock
  20. #20 Re: Ported LIM & Ported SC vs Stock - GEN 3 gains?
    Correct.
  1. ported gen 3 n stock lim?
    By kurt5153 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2011, 12:31 AM
