Thread: Original owner ran 87 octane..Bad?
Results 1 to 19 of 19
  1. #1 Original owner ran 87 octane..Bad?
    SE Level Member KoreyGTX's Avatar
    Ontario, Canada
    Hey,
    Pretty new here as i just bought my first GP last week. It's a '99 GTX.
    The guy I bought it off of (which is also the original owner) ran 87 Octane in it it's entire life until now. I'm aware that the car was designed to use premium fuel, and am wondering what effects being run on 87 for 9 years could have caused? Should I be worried about this? I assume I should start running 91 octane in it?
    One more question..Is it harmful to switch back and fourth between grades of fuel for testing purposes (eg fuel mileage).
    Any help is much appreciated as I'm super pumped to get some miles on her.
    Thanks
  2. #2 Re: Original owner ran 87 octane..Bad?
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    As long as you don't have any chipped pistons from it I'd say your fine. I wouldn't advise running 87 octane again unless you don't go WOT through that entire tank. The lower octane will exponentially increase your KR, which will increase the chance of you grenading a piston.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  3. #3 Re: Original owner ran 87 octane..Bad?
    Ontario, Canada
    "WOT" ?
    Alright, and i dont really know if a piston is damaged unless i rip it apart or something goes boom?
  4. #4 Re: Original owner ran 87 octane..Bad?
    Barksdale AFB, LA
    Quote Originally Posted by KoreyGTX View Post
    "WOT" ?
    Wide open throttle.
    2009 Subaru Impreza WRX STI
  5. #5 Re: Original owner ran 87 octane..Bad?
    Donating Users blowfishRus6's Avatar
    g.a.
    dang thats a pretty rare car. and well if the guy babied the car, it should be good. arent the gtx's already intercooled??? i dont much about them. if it is intercooled your good cause i dought you have any KR. they say to use higher grade fuel to fight off KR.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  6. #6 Re: Original owner ran 87 octane..Bad?
    Jul 2008
    Dekalb, IL
    Quote Originally Posted by blowfishRus6 View Post
    No GTX's came intercooled. I think your thinking of the GPX concept which iirc was supposed to have an intercooler.
  7. #7 Re: Original owner ran 87 octane..Bad?
    SE Level Member sgdude's Avatar
    Las Cruces, NM
    it should be fine, my car ran regular all its life 2, no problems
  8. #8 Re: Original owner ran 87 octane..Bad?
    g.a.
    Quote Originally Posted by Smokin2000gtp View Post
    ahh. like i said. i dont know much about them
    its slow.
  9. #9 Re: Original owner ran 87 octane..Bad?
    NE Ohio
    previous owner of my car ran nothig but 87. now its getting 93 and loving it.
  10. #10 Re: Original owner ran 87 octane..Bad?
    Hoffman/Schaumburg, IL
    My gt had KR on 87, so I've ran 93 for 2+ yrs now
  11. #11 Re: Original owner ran 87 octane..Bad?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    You should be fine. The computer commands lowered timing when low octane fuel is being used, to protect the engine.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  12. #12 Re: Original owner ran 87 octane..Bad?
    Ontario, Canada
    Thanks guys, I'm liking this forum. Lots of help!
    I should probably start running a higher octane fuel though I suppose. Even going to 89 would help i think. Or maybe I should just suck it up and pay the extra $7 or so a tank for 91.
  13. #13 Re: Original owner ran 87 octane..Bad?
    NE Ohio
    i dont know how it is where you live but 91-93 is only 20 cents more than 87 here.
    so lets say you have a completely empty tank.
    .20 x 16 = 3.20. however, youll rarely get more than 14 gallons at a time, so its more like an extra $2.80 every tiem you fill up from e.
    2.80 x 52 = $145.60 (assuming you have to fill up once a week, i get over 400 miles on a tank of gas)
    a new motor from ed is going to cost at least 1k, so you make the choice. is it worth an extra $150 a year to insure that your motor wont blow up?
    hope that helps put it in perspective.
  14. #14 Re: Original owner ran 87 octane..Bad?
    Las Cruces, NM
    yeah, i only drive ~5k miles per year and get 400 miles per tank, so maybe $50-$60 a year more for premium? even if u drive alot more, it amounts to a few cents a day
  15. #15 Re: Original owner ran 87 octane..Bad?
    NE Ohio
    yep. the small price to pay for the required gas far outweighs the price of having to swap a new motor in because of trying to save a few buks.
  16. #16 Re: Original owner ran 87 octane..Bad?
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    How the hell are you guys getting 400 Miles per tank that is pretty good
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  17. #17 Re: Original owner ran 87 octane..Bad?
    NE Ohio
    i drive like a grandmother.
  18. #18 Re: Original owner ran 87 octane..Bad?
    Ontario, Canada
    True true. I can suck up the $$ issue. As long as its not too late after it running on 87 for 9 years.
    AS far as a difference in price, its about 10+ cents more per liter here for premium. So at about 65 liters to fill up thats $6.50 more per fill up. But liek some of you said, its cheaper then buying a new engine
  19. #19 Re: Original owner ran 87 octane..Bad?
    NE Ohio
    oh, youre in canada. ok, thats a little different. but still, lol.
  1. What is octane? KR? Explained here.
    By Reptile in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-21-2013, 07:33 AM
  2. How much octane booster?
    By Sabrewings in forum General Tech Discussion
    Last Post: 08-18-2009, 11:19 PM
  3. Lowered the octane!!!
    Last Post: 05-22-2008, 05:05 PM
  4. Octane booster
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2008, 02:04 PM
