Thread: higher than useual temps Am I over reacting?
Results 1 to 9 of 9
  1. #1 higher than useual temps Am I over reacting?
    GT Level Member papaspanky's Avatar
    Jul 2010
    new england
    since I have put headers on my 06 gt I have noticed that under light load my coolant temp sometimes reaches 205 I do have the wonderful flex pipe tick am I over reacting or should I not worry. my fuel trims pretty good.
    81 T/A pure Pontiac 350,700r4 3.23's coming soon pure Pontiac 462 06 gt wizaird,XS power Headers,zzp ss ic,overkill tune 180 stat autolite 104's, 3.6 pulley.Special Edition HORNY DRIVER mod.
  2. #2 Re: higher than useual temps Am I over reacting?
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    try wrapping any exposed brass part of the coolant temp sensor with teflon tape/high temp tape, i feel like the excessive underhood temps heat soak the sensor. worth a try. let me know if it works for you.
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  3. #3 Re: higher than useual temps Am I over reacting?
    Cambridge, Ontario Canada
    205 ok imo. I start worrying about 212 and up if just cruising on the highway.
    2005 E55 - stock
  4. #4 Re: higher than useual temps Am I over reacting?
    Mar 2012
    Dallas
    i think what he is getting at is, he has a 180 tstat and more than likely has fans programmed to turn on at 180-185, temps in the 200s would upset me too.
  5. #5 Re: higher than useual temps Am I over reacting?
    I see 200-208 like when I am crusing on the freeway in the summer.
  6. #6 Re: higher than useual temps Am I over reacting?
    Jul 2010
    new england
    the thing is it runs 181 or so and now its running higher.
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Well a good place to start is drain and flush your coolant. Refill and see if it still does it.
  8. #8 Re: higher than useual temps Am I over reacting?
    Jul 2010
    new england
    ok I wrapped the temp sensor and the crossover pipe. neither did much to lower temps. I flushed my cooling system bled all air still same problem. thinking about this it all started when I put the headers on now I'm wondering if I am running lean. my fuel trims have been pretty good useually + or - 2 to 5 sometimes more but not for long.and I have no knock and i also replaced a broken coolant elbow. this has me stumped anybody got any other ideas?
  9. #9 Re: higher than useual temps Am I over reacting?
    Out West
    Quote Originally Posted by papaspanky View Post
    normal
    Whine with your Cheese?
  1. What gives the L36 Higher Compression?
    By BlackGT97 in forum General Tech Discussion
    Last Post: 04-10-2012, 09:52 PM
  2. Car won't rev up higher than 3000rpm in any gear.
    By checkinpox in forum General Tech Discussion
    Last Post: 12-12-2011, 06:04 PM
  3. crazy high trans temps or no temps!? pics!
    By blknbstd in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-20-2011, 06:07 AM
  4. Higher Than a Kite!
    By BoostenGTP in forum Visual/Body Modifications
    Last Post: 01-16-2011, 12:18 AM
