Thread: lifter preload procedure.
Results 1 to 20 of 24
  1. #1 lifter preload procedure.
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    is it the same as lets say on a chevy 350 sb, where you turn the engine over to intake starting to open to set exhaust preload and exhaust opening to set intake preload? zero lash plus 1/2 turn for the 350 sb
    if i remember correct it was 16ft lbs plus 90*
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  2. #2 Re: lifter preload procedure.
    I'm not sure people follow that.
    They get reusable bolts and torque to 23-25 ft lbs and move on.
  3. #3 Re: lifter preload procedure.
    Mar 2012
    Dallas
    so it does not matter which valve is closed or open on our engine? you just torque down the rocker bolts to the tq spec and go on down the line?
  4. #4 Re: lifter preload procedure.
    I've never seen a solid answer on that one.
  5. #5 Re: lifter preload procedure.
    Jan 1970
    Maquoketa, Iowa
    It depends on the setup but you are close enough, zero lash with the other valve open then .5 to 1.5 turns. The stock lifters are supposed to be a little more forgiving than the comp cams in that the stock lifters are good for 1/2 turn to 1 1/2 turns and the comp cams around 3/8ths to 1/2 iirc. Most just try to keep the lifters, pushrods, rockers etc. in the same layout as they are going to put them back in, torque the rocker bolts and thats about it.
    When you start changing the hg thickness, rocker, head milling, valves, cam then you have to account for a little more.
  6. #6 Re: lifter preload procedure.
    Apr 2009
    Fort Worth TX
    Stock valve train = torque to spec
    Modified valve train = torque to spec - providing correct spacers are installed to achieve correct geometry.
    This is nothing like the old engines that required pre-load adjustment and rocker nuts with locks.
  7. #7 Re: lifter preload procedure.
    Mar 2012
    Dallas
    im kind of confused.
    so on our engines, we do follow that procedure(with stock lifters) by tightening down the rocker bolt to zero lash and then 1/2 turn?
    or
    just the 16ft. lbs. plus 90*
    also during the torque down procedure, is it on the closed valve? i have heard of people just tightening them down to the torque spec whether they are open or closed.
  8. #8 Re: lifter preload procedure.
    Apr 2009
    Fort Worth TX
    Just torque them to spec. There is no pre-load procedure. It doesn't matter which valve is open or closed.
  9. #9 Re: lifter preload procedure.
    Mar 2012
    Dallas
    Quote Originally Posted by Rico View Post
    gotcha, how would the torque be to full spec, if the spring is pushing against the rocker when it is opening the valve?
    rico, are you by chance the guy who needed new heads bc your rockers grenaded?
  10. #10 Re: lifter preload procedure.
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by TEK310 View Post
    Spring tension will not effect the torque.
    Funny guy, aren't you? I wanted the heads to do some porting.
    Over 30K on my rebuilds with stock valve train and no problems.
  11. #11 Re: lifter preload procedure.
    Mar 2012
    Dallas
    lol, did not mean that as a joke, i have a set of used L67 heads for sale on craigslist and someone from ft worth had been interested in them a while back. says you are in ft worth so i was not sure. im in mesquite/dallas
  12. #12 Re: lifter preload procedure.
    Apr 2009
    Fort Worth TX
    I'm northwest of Fort Worth...it's called Blue Mound near Saginaw.
    Are you the guy that never sent me the pictures?
  13. #13 Re: lifter preload procedure.
    Mar 2012
    Dallas
    more than likely. does your # end with 0879?
  14. #14 Re: lifter preload procedure.
    Apr 2009
    Fort Worth TX
    0687
  15. #15 Re: lifter preload procedure.
    Mar 2012
    Dallas
    oh, different guy then.
  16. #16 Re: lifter preload procedure.
    For torquing rockers with reusable bolts. I torque them down to the spec. Turn the motor a couple of times by hand and retorque to ensure none were bound by being partially open. Ideally you'd TDC each cylinder and torque it w/o any pressure on the rockers. It's just not happening in my world though.
  17. #17 Re: lifter preload procedure.
    Apr 2009
    Fort Worth TX
    Bill
    We're in the same world. It probably takes less than 1/4 of a ft-lb to compress the spring.
  18. #18 Re: lifter preload procedure.
    I've had one or two bind a little somehow..so turning the motor a bit helps my peace of mind.
  19. #19 Re: lifter preload procedure.
    Mar 2012
    Dallas
    what about with TTY bolts? say mine have already been torqued down, and ran for about 3k miles, can i retorque them without them loosening up on me?
  20. #20 Re: lifter preload procedure.
    Apr 2009
    Fort Worth TX
    Reuse TTY bolts at your own risk. Torque them to 20 ft-lb and stop.
    If I were you I would just get some reusable bolts...peace of mind.
  1. Procedure for dropping the oil pan on GTP?
    By anicolay in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2011, 06:18 PM
  2. Lifter Preload?
    By IBLOWN in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-29-2011, 07:59 AM
  3. Preload on OE-R Lifters?
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2010, 03:57 AM
  4. Procedure to program the BCM
    By darinparsons99 in forum General Tech Discussion
    Last Post: 10-26-2009, 09:30 PM
  5. Procedure for changing diff while in the car.
    By machine head in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-03-2009, 03:15 PM
