Thread: lifter preload procedure.
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: lifter preload procedure.
    Cambridge, Ontario Canada
    Not to jack but can you reuse stock rocker bolts to tq down stock rockers?
    2005 E55 - stock
  2. #22 Re: lifter preload procedure.
    Mar 2012
    NC
    Nope, they're torque to yield and not reusable. Fortunately, they're only like $20 from just about any vendor.
  3. #23 Re: lifter preload procedure.
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    Quote Originally Posted by Rico View Post
    Reuse TTY bolts at your own risk. Torque them to 20 ft-lb and stop.
    If I were you I would just get some reusable bolts...peace of mind.
    not talking about backing them out, just torquing them down further. that 20ft-lb surely its more after the 90* turn added to the 16ft-lb
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  4. #24 Re: lifter preload procedure.
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by TEK310 View Post
    I assumed that you already stretched the bolts.
    The additional angle required by spec is designed to stretch the bolt. The TTY bolts are actually treated as a spring. When they are stretched once they should not be stretched again.
    I suggested 20ft-lb because this is about the limit on a used TTY rocker bolt before it begins to stretch. Further stretch will weaken the used bolt.
  1. Procedure for dropping the oil pan on GTP?
    By anicolay in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2011, 06:18 PM
  2. Lifter Preload?
    By IBLOWN in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-29-2011, 07:59 AM
  3. Preload on OE-R Lifters?
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2010, 03:57 AM
  4. Procedure to program the BCM
    By darinparsons99 in forum General Tech Discussion
    Last Post: 10-26-2009, 09:30 PM
  5. Procedure for changing diff while in the car.
    By machine head in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-03-2009, 03:15 PM
