Thread: LIM job just finished & still ticking!! VIDEO & Help! **UPDATED July 19**
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21 Re: LIM job just finished & still ticking!! VIDEO & Help!
    Jun 2012
    820a louisiana ave, saint cloud, FL, 34769, United States
    its most likely a lifter. i just went threw this same thing. ended up being a lifter.
  2. #22 Re: LIM job just finished & still ticking!! VIDEO & Help!
    Cambridge, Ontario Canada
    ok well I managed to finess the valve cover out without taking the alternator bracket or coolant elbows completely out I fired up the car with no valve cover and everything visually looks ok. What is my next step? Can I remove rockers & look at pushrods? I am really hoping to figure this out before going in to replace a darn lifter.
    2005 E55 - stock
  3. #23 Re: LIM job just finished & still ticking!! VIDEO & Help!
    have you put seafoam in the oil yet?
  4. #24 Re: LIM job just finished & still ticking!! VIDEO & Help!
    Didnt put seafoam in the oil. From what I read it appeared the top end method is the method that cures lifter tick if possible. Car is 50% apart now...
    2005 E55 - stock
  5. #25 Re: LIM job just finished & still ticking!! VIDEO & Help!
    GT Level Member NR92's Avatar
    Atkins, Ia
    Quote Originally Posted by Elite6 View Post
    putting seafoam in the vacuum system (sounds like what you did) isnt going to help with lifter noise, your going to have to try putting some in the oil when you put it back together
    2004 GTP Comp G -- Sold
    2006 GTO Magnuson supercharged
    2007 Ram 2500 QCSB 4x4 5.9 Cummins, Efi live, Exhaust, Intake N'stuff
  6. #26 Re: LIM job just finished & still ticking!! VIDEO & Help!
    Yeah try some in the oil I'll bet the tick goes away.
  7. #27 Re: LIM job just finished & still ticking!! VIDEO & Help! **UPDATED July 19**
    I did the whole LIM job the first time, car back together & still ticking. Decided it must have been the lifters, did LIM job again (of course gaskets got a slight tear when trying to clean - needed new ones). Get car back together 10 mins ago & fire up... STILL TICKING!!! !!
    Decided I would try the injectors but can't imagine them making that noise!! Pull 1,3,5 no change... Pull 2 no change, pull 4 and noise gets much quieter!! Seriously? I never ever would have guessed the injectors could possibly be that loud. Going to junkyard to grab some - bloody hell man.
    Are GT injectors the same?
    2005 E55 - stock
  8. #28 Re: LIM job just finished & still ticking!! VIDEO & Help! **UPDATED July 19**
    They are different. You need gtp inj
  9. #29 Re: LIM job just finished & still ticking!! VIDEO & Help! **UPDATED July 19**
    Well swapped injector and still have noise. I am at a loss now. Lifters replace, pushrods and rockers looked ok, springs looked ok... Could it be fuel rail?
    2005 E55 - stock
  10. #30 Re: LIM job just finished & still ticking!! VIDEO & Help! **UPDATED July 19**
    boroscope and look through the plug hole and see if the valve is maybe bent or chipped piston?
  11. #31 Re: LIM job just finished & still ticking!! VIDEO & Help! **UPDATED July 19**
    any chance its an exhaust leak?
  12. #32 Re: LIM job just finished & still ticking!! VIDEO & Help! **UPDATED July 19**
    At this point anything is possible. How can i tell for sure? I do notice a little bit of smoke from underneath rear valve cover. I thought it was oil burnoff but not sure...
    2005 E55 - stock
  13. #33 Re: LIM job just finished & still ticking!! VIDEO & Help! **UPDATED July 19**
    the only way short of seeing a black area at a connection or right at the head, is to when the car is ice cold, start it up and pass your hand over all exhaust parts, ( idea is to feel the leak hit your hand) where parts meet and so on. it will get hot fast, so be kinda quick about it.
    i had a missing exhaust bolt in my 03 gmc, i could hear a ticking when it was cold, but as it warmed up the tick went away. the manifold and heads got expanded from the heat and it would seal up.
  14. #34 Re: LIM job just finished & still ticking!! VIDEO & Help! **UPDATED July 19**
    It does look like a new flex is on the back by the rear header
    2005 E55 - stock
  15. #35 Re: LIM job just finished & still ticking!! VIDEO & Help! **UPDATED July 19**
    Did some reading, I think I can put the car in gear, hold the brake and give it some gas. If the noise goes away it is the flexplate? At this point its got to be either
    1. Flexplate
    2. Nasty Exhaust leak
    3. Bent valve
    4. F bombed rods?
    2005 E55 - stock
  16. #36 Re: LIM job just finished & still ticking!! VIDEO & Help! **UPDATED July 19**
    Flex plate looks ok from my limited view under the car and bolts are tight. Didnt hear any change when brake torquing either. I did notice a little leak from the damn lim gaskets. Cant believe it so its either exhaust or worse i guess.
    2005 E55 - stock
  1. Ticking noise or am i losing my mind? (video)
    By GTLGDP in forum General Tech Discussion
    Last Post: 03-09-2012, 10:21 PM
  2. Something ticking (Video)
    By fri3dchick3n in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-21-2011, 01:45 AM
  3. Finished!!
    By blueguy in forum Off Topic Discussion
    Last Post: 04-03-2009, 03:17 AM
  4. Im finished, its over with, Im done
    Last Post: 02-21-2009, 10:35 PM
  5. My New, Actually Of The GTP, Video (Finished!)
    Last Post: 11-06-2008, 03:14 PM
