Was your #4 wire really tight across the SC body, and almost the same length as the #2 wire? Mine is laying right up against the SC housing, and if it weren't for the wire seperators, it would be laying on the SC housing.
Loud
Loud
try running them under the snout.
Tried that. Because it's gotta come back up and over the bracket in the back, it's still too short.
Loud
Number 4 should be the longest wire. Pull them off...you should have one back one that is longer.
LOL, plug brackets.
LOL@routingoverthesupercharger.
Remove that alternator bracket, that might help you too.
Yeah, if it's that tight, then you might need to lay the back 3 out and check for the longest.
Under the snout is the only way to go.. Route them like this and win
