Thread: Question for the PRJ wire users out there
Results 1 to 10 of 10
  1. #1 Question for the PRJ wire users out there
    Jun 2012
    Pennsylvania
    Was your #4 wire really tight across the SC body, and almost the same length as the #2 wire? Mine is laying right up against the SC housing, and if it weren't for the wire seperators, it would be laying on the SC housing.
    Loud
  2. #2 Re: Question for the PRJ wire users out there
    try running them under the snout.
  3. #3 Re: Question for the PRJ wire users out there
    Jun 2012
    Pennsylvania
    Tried that. Because it's gotta come back up and over the bracket in the back, it's still too short.
    Loud
  4. #4 Re: Question for the PRJ wire users out there
    Whats wrong with them laying on it?
    They wont burst into flames.
  5. #5 Re: Question for the PRJ wire users out there
    Number 4 should be the longest wire. Pull them off...you should have one back one that is longer.
  6. #6 Re: Question for the PRJ wire users out there
  7. #7 Re: Question for the PRJ wire users out there
    LOL, plug brackets.
    LOL@routingoverthesupercharger.
    Remove that alternator bracket, that might help you too.
  8. #8 Re: Question for the PRJ wire users out there
    Remove....c'mon. I leave that baby there.
  9. #9 Re: Question for the PRJ wire users out there
    Florida
    Yeah, if it's that tight, then you might need to lay the back 3 out and check for the longest.
    Under the snout is the only way to go.. Route them like this and win
  10. #10 Re: Question for the PRJ wire users out there
    Portland Oregon
    Back when I had prj wires the back three were all equal length. Same with the fronts. They must have changed things around a tad in the last 4 years
  1. wire harness question
    By 2dee11 in forum Audio, Security & Visual Electronics
    Last Post: 03-10-2012, 03:42 PM
  2. injector wire diagram or question
    By TeacherCreature in forum General Tech Discussion
    Last Post: 10-13-2011, 12:26 AM
  3. power wire question?
    By Dragonblaze in forum Audio, Security & Visual Electronics
    Last Post: 09-17-2010, 01:23 PM
  4. spark plug wire question
    By copperpacecar in forum General Tech Discussion
    Last Post: 05-12-2010, 12:20 AM
  5. amp remote wire question
    By chrissbee77 in forum Audio, Security & Visual Electronics
    Last Post: 08-20-2009, 11:44 PM
