Thread: Port my LIM???
Results 1 to 13 of 13
  1. #1 Port my LIM???
    GT Level Member YoungGTP's Avatar
    Aug 2008
    Iowa
    Should i or should i not port my LIM when i install a P&P gen3 sc w/ N* tb? if i should what would be the best to do with stock heads? any ideas?
    -98 GTP Thunderstorm
    Cai, 3.5 press on pulley, NGK TR6's, 3" to 2.5" exhaust, thrush glasspacks, drilled 180 t-stat soon-overkill pcm, fully ported sc, N* TB, and LQ4 MAF, Future- Full I/C, XP cam, s&s headers
  2. #2 Re: Port my LIM???
    Banned
    Wichita Falls, Texas
    No reason to do so. Actually from my own personal experience, on my own vehicle. When we did this I actually lost noticeable power. With stock heads of-course.
  3. #3 Re: Port my LIM???
    youd have to gasket match the heads with it for it to make any difference. otherwise there will be a step from the lower intake to the heads.
  4. #4 Re: Port my LIM???
    Barksdale AFB, LA
    What about if you are going intercooled?
    2009 Subaru Impreza WRX STI
  5. #5 Re: Port my LIM???
    Banned
    Quote Originally Posted by Sabrewings View Post
    Still pointless. The heads aren't the same size as the outlets on your ported LIM. All it's going to do is cause turbulence in the airflow.
  6. #6 Re: Port my LIM???
    Aug 2008
    Iowa
    alright. well thats a good thing just saved money on lim gaskets then. yey. thanks guys
  7. #7 Re: Port my LIM???
    Barksdale AFB, LA
    Quote Originally Posted by Street Wolf View Post
    I was referring more to the inlet of the LIM... make more use of the IC core.
  8. #8 Re: Port my LIM???
    Banned
    Well yeah, thats usually referred to as 'Machining' the LIM though. Didn't know thats what you were talking about.
  9. #9 Re: Port my LIM???
    Aug 2008
    Iowa
    would that also make more use of the sc or not with the outlet size only being so big
  10. #10 Re: Port my LIM???
    Aug 2008
    Iowa
    bump
  11. #11 Re: Port my LIM???
    my blower case and lower intake are ported and im non-intercooled. havent seen any ill effects as of yet.
  12. #12 Re: Port my LIM???
    if I happen to find another or fix my totalled car prior to your purchasing my blower I can surely add my ported LIM in on the deal for an added price (inlet porting only)
    but that is up to you PS I sent pics, I found them on my girls photobucket
  13. #13 Re: Port my LIM???
    Aug 2008
    Iowa
    yea i saw that. i didnt know if the inlet porting helped any, but no need to by it, i can inlet port myself (cut off wheel!!!!) haha. im thinking im gonna stay stock lim now, cause i noticed that lim gasket plus some other stuff that i would want to replace would cost me another 50 that i dont need to spend at the moment (thanks though)
  1. Trans pressure test port fitting
    By Sabrewings in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-17-2008, 11:01 AM
  2. What size is the fuel pressure test port?
    By alacran in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2008, 08:27 AM
