Is there a certain way to mount the icm, coils on a angle so doesnt hit the sc belt
just loosen the top bolts and put washers behind them and tilt it up. That's what I did and it works great. Or get the bonneville bracket, which I plan on installing soon.
Go to the hardware store and look for bolt spacers, then get a longer bolts for the ICM bracket.
I had it done a while back but just installed a cam and when i idle it makes a squeaky noise and tried to tighten the washers but still has little play side to side so maybe the bolt aint fitting right
Is it had to install the bonneville bracket
Sam - every intercooled car youve ever seen in person had their coil packs spaced the way I did yours =p. Next time I see you I will check it out and make sure its tight and not squeaking. .
Go here and view the second PDF called "S2 S3 Intercooler installation instructions v.2.pdf". ZZPs instructions actually show what I did to yours.
http://s3.amazonaws.com/zzpstorage/i...IC+Install.zip
