Thread: Coils, icm postion after intercooler installed
Results 1 to 8 of 8
  1. #1 Coils, icm postion after intercooler installed
    SE Level Member samuelcb409's Avatar
    Galveston, Texas
    Is there a certain way to mount the icm, coils on a angle so doesnt hit the sc belt
    MODS: 3.0 MPS, CAI, SD Headers w/Custom 3"DP, 160* T-Stat, NGK TR6, Full Size intercooler, #42.5s, Ported LIM & Gen III, LS1 TB w/85mm MAF , s1x Cam, #90 Springs, Intense Pushrods, EGR Delete, Cat and U Bend Delete, Magnaflow Resonator & Mufflers, Fully Built ZZP Trans, 2800 stall Tuned by KHP Peformance
  2. #2 Re: Coils, icm postion after intercooler installed
    Resident ZZP Leg Humper BoostenGTP's Avatar
    Grand Rapids, MI
    just loosen the top bolts and put washers behind them and tilt it up. That's what I did and it works great. Or get the bonneville bracket, which I plan on installing soon.
    2014 Mustang GT Sterling Grey 5.0 Track Package NEW 2000 Grand Prix GTP Red SOLD
    2000 Mustang GT LTR SOLD 2000 Grand Prix GTP Silvermist SOLD
  3. #3 Re: Coils, icm postion after intercooler installed
    Mar 2012
    NC
    That's what I'm doing. I custom made a metal P/S upper engine mount because the necessary aluminum L36 Impala upper mounts break too easy. Keep that in mind.
  4. #4 Re: Coils, icm postion after intercooler installed
    Minnesota
    Go to the hardware store and look for bolt spacers, then get a longer bolts for the ICM bracket.
  5. #5 Re: Coils, icm postion after intercooler installed
    Galveston, Texas
    I had it done a while back but just installed a cam and when i idle it makes a squeaky noise and tried to tighten the washers but still has little play side to side so maybe the bolt aint fitting right
  6. #6 Re: Coils, icm postion after intercooler installed
    Galveston, Texas
    Is it had to install the bonneville bracket
  7. #7 Re: Coils, icm postion after intercooler installed
    Donating Users Tengis's Avatar
    Houston
    Sam - every intercooled car youve ever seen in person had their coil packs spaced the way I did yours =p. Next time I see you I will check it out and make sure its tight and not squeaking. .
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  8. #8 Re: Coils, icm postion after intercooler installed
    Houston
    Go here and view the second PDF called "S2 S3 Intercooler installation instructions v.2.pdf". ZZPs instructions actually show what I did to yours.
    http://s3.amazonaws.com/zzpstorage/i...IC+Install.zip
    Satin Purple 97 GTP
  1. windshield wipers stuck in up postion
    By loganrick in forum General Tech Discussion
    Last Post: 01-10-2012, 12:21 AM
  2. Intercooler installed but car won't start?
    By Pure2sin in forum General Tech Discussion
    Last Post: 06-03-2011, 10:50 PM
  3. zzp intercooler vs wbody store intercooler ?
    By boostedgtp13 in forum Off Topic Discussion
    Last Post: 05-04-2010, 02:40 AM
  4. Installed a Gen V SC onto Gen III Intercooler?
    By geforcextreme in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2010, 11:01 PM
