Thread: engine swap question
Results 1 to 7 of 7
  1. #1 engine swap question
    SE Level Member chrisLB's Avatar
    Nov 2009
    canada
    i have a doner car with very low mileage and its ready for the engine and transmission to be pulled im just wondering if i can do a straight engine, transmission swap to my 97 from a 2001 gtp? im leaving the 97 throttle body.
  2. #2 Re: engine swap question
    Feb 2009
    flintnasty MI
    trans line hookups will be different... injector connectors will be different.... you will need to put a ~01 gtp pcm in it.
  3. #3 Re: engine swap question
    Scott...why would he need an 01 pcm? TCC strategy?
    Trans lines, yes.
    he could definately put the 97 TB on it.
    He should be able to reuse his injectors from the 97
  4. #4 Re: engine swap question
    Should they not both be minitimer connectors?
    You should use the TB for the PCM you use.
  5. #5 Re: engine swap question
    If you put this stuff into a 97 shell with 97 wiring. You need to use the 97 pcm .
  6. #6 Re: engine swap question
    Nov 2009
    canada
    The trans lines to the rad are different or the wiring?
  7. #7 Re: engine swap question
    both are, your going to need the wire harness off the 97 and its pcm it seems. and the trans lines. thats how im reading it.
  1. Engine Swap Question
    By Points70 in forum General Tech Discussion
    Last Post: 04-18-2012, 06:45 AM
  2. 3800 Engine swap question (lesabre to GP)
    By 1gr869 in forum General Tech Discussion
    Last Post: 01-19-2011, 10:50 PM
  3. engine swap question!
    By gagemonster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2010, 10:52 PM
  4. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  5. engine swap question!!!!
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2008, 12:27 PM
