Thread: PCV Valve Bypass/Delete
Results 1 to 12 of 12
  1. #1 PCV Valve Bypass/Delete
    Minnesota
    I have a gen v s/c and lim. I am wondering what the procedures are or how you woulld be able to bypass the pcv. I have heard of people doing it in the past but dont quite remember how to exactly do it.
  2. #2 Re: PCV Valve Bypass/Delete
    Jan 2012
    Philadelphia
    why would you want to? curious because im doing a gen 5 swap
  3. #3 Re: PCV Valve Bypass/Delete
    Minnesota
    Only reason to do this would be to run an external PCV and catch can. Unless you are installing an intercooler which blocks off the PCV, you won't need to do it.
    If you are dead set on doing it I will get you the information.
  4. #4 Re: PCV Valve Bypass/Delete
    On a Gen V there is an external hose. put the can on there if that's the goal.
  5. #5 Re: PCV Valve Bypass/Delete
    SE Level Member RedPrix03's Avatar
    Sep 2015
    Sioux Falls, SD
    Quote Originally Posted by Pure2sin View Post
    Is there a PCV delete kit or something similar that i can look for, or what is required to do it? I REALLY want to do a PCV delete. I have a GT If that changes anything. Thanks
  6. #6 Re: PCV Valve Bypass/Delete
    why would you delete the pcv? on a n/a engine even? this is a pcv by pass thread to make it still work with a gen 5 blower swap.
    whole catch can idea on a 3800 is silly too.
  7. #7 Re: PCV Valve Bypass/Delete
    Sep 2015
    Sioux Falls, SD
    Quote Originally Posted by ScottyDoggs View Post
    Sorry, I just figured one of these guys may have an idea about what to do. I heard it has a negative effect in conjunction with the EGR. Supposedly it leaves oil and sludge everywhere in the intake and exhaust valves and sometimes makes quite a mess in the upper intake manifold too
  8. #8 Re: PCV Valve Bypass/Delete
    just because it oils up the lim dont mean its wrong, egr has noting to do with the pcv either. and the egr can be deleted with no issues. as long as its tuned out.
  9. #9 Re: PCV Valve Bypass/Delete
    Sep 2015
    Sioux Falls, SD
    Haha ok for the info, I don't know much about the PCV or the EGR so i'm just basing my information off of what i've heard. I may just go the route of an EGR delete then for my build!
  10. #10 Re: PCV Valve Bypass/Delete
    "build".
    I delete the EGR on every 3800 I have. Not only does it clean up the bay, but it prevents the TB gunking up with carbon over time as well. All the people that gripe you lose all this 2~ MPG business...care way too much about gas mileage.
  11. #11 Re: PCV Valve Bypass/Delete
    Quote Originally Posted by blueguy View Post
    "build".
    nothing has made my mpg better or worse for local driving. year round 13.9 - 14.2 ish. egr deleted now, top swapped ported heads rockers headers still the same mpg as the l67 stock, or with the 3.4 set and rockers.
  12. #12 Re: PCV Valve Bypass/Delete
    Sep 2015
    Sioux Falls, SD
    "build".
    Well, I AM actually doing a build but I am taking my time doing it... I want everything to be right the first time, hence the reason why i am asking around for advice (No intention to sound like a rookie). Anyways i want this engine staying as clean as it can internally (as clean as an engine can get at least) so i don't have a bunch of crap sitting and gunking up on valves and etc. throughout the engine, as you said. I don't care much about mileage anyways haha. Why worry about MPG's when you're having fun?
  1. Boost Bypass Valve is it the same as a BOV?
    By xsvtank in forum General Tech Discussion
    Last Post: 08-06-2010, 12:12 PM
  2. Boost Bypass Valve help
    By mikeh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2009, 01:20 AM
  3. Boost BYpass Valve capped Off?????
    By Uno99 in forum General Tech Discussion
    Last Post: 10-19-2009, 07:48 PM
  4. m90 bypass valve question
    By bhrfpa11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-04-2009, 04:44 PM
