Thread: 160 or 180 degree thermostat??
Page 1 of 3 123 LastLast
Results 1 to 20 of 46
  1. #1 160 or 180 degree thermostat??
    SE Level Member Sean1998Daytona's Avatar
    Mar 2012
    Milwaukee, Wisconsin
    i have a 1998 daytona gtp and i was wonderin if i should get a 160 degree or 180 degree thermostat swap? i was told that getting a cooler thermostat will help increase power. is this true? and which one should i get? thanks...
  2. #2 Re: 160 or 180 degree thermostat??
    Banned
    CT
    They don't technically increase power. It's a touchy subject around here but IMO just get a 180. It'll help to keep things a little cooler and by a little I really mean a little, lol. 160 is too cold though.
  3. #3 Re: 160 or 180 degree thermostat??
    180 if you plan on going past a 3.4 pulley or 195 otherwise.
    Especially with WI in mind.
  4. #4 Re: 160 or 180 degree thermostat??
    Pennsylvania
    Just stay 195, 180 only makes your car take longer to warm up and 160 can actually cause damage and set codes... I read in Jerry's Tuning Notebook or whatever that cooler thermostats actually accelerate wear on an engine up to 300%.
    Sport Edition Kv5 18x8
  5. #5 Re: 160 or 180 degree thermostat??
    Quote Originally Posted by FriboRage View Post
    Jerry also doesn't believe in wide band O2 sensors.
  6. #6 Re: 160 or 180 degree thermostat??
    The little bit it does cool it (5-10º F), its not even worth it.
    Thats my opinion anyway.
  7. #7 Re: 160 or 180 degree thermostat??
    Pennsylvania
    Well I dont know, I just read over it and that stuck in my head
  8. #8 Re: 160 or 180 degree thermostat??
    Banned
    CT
    I'm not sure how a 180 could have any effect what so ever on how quickly the car warms up.
  9. #9 Re: 160 or 180 degree thermostat??
    Jun 2011
    Someone needs to edit the safely modding your 3800 thread.
  10. #10 Re: 160 or 180 degree thermostat??
    Pennsylvania
    Quote Originally Posted by SnowFlake View Post
    I figure if it opens sooner, it would stay cooler longer, albeit a small amount?
  11. #11 Re: 160 or 180 degree thermostat??
    It wouldn't at all.
    if you run a 180 your ect's should be in the 180's.
  12. #12 Re: 160 or 180 degree thermostat??
    Mar 2012
    ok cool thanks! i just wont even bother with getting a new one
  13. #13 Re: 160 or 180 degree thermostat??
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    I'd recommend the 180, if you plan on doing any auto-x or really any type of racing it helps keep temperatures constant.
  14. #14 Re: 160 or 180 degree thermostat??
    May 2008
    Winnipeg, MB
    180 if your taking it to the track, otherwise its not a good idea for a DD, I have a 180* sitting on a shelf now because I have changed my mind about using it
    2007 Pontiac Grand Prix
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    I'd like someone to come up with some conclusive evidence that running a 180* tstat isn't good for our cars.
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  16. #16 Re: 160 or 180 degree thermostat??
    Quote Originally Posted by dazedandconfused View Post
    Prove your case as well then.
  17. #17 Re: 160 or 180 degree thermostat??
    Florida
    down here in florida i recommend the 180 stat as it keeps engine temps between 176-195 depending on fan settings. maybe back in the day people who ran too much pulley and were lean would throw in a 160* cause if they get their car that cool and keep it there the car will command more fuel... and this would help get a better AF. this is a very bad idea and with the tuners out there and pcms it is not an option at all.
    Jan 2009
    Tallahassee, FL
    There is a thing called operating temp where mechanical devices are more efficient at. Why do you think our cars came with a 210* or whatever stat from the factory?
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  19. #19 Re: 160 or 180 degree thermostat??
    Banned
    CT
    Quote Originally Posted by Sandman View Post
    195* not 210.
    Dropping 15 degrees is going to have zero ill effects.
  20. #20 Re: 160 or 180 degree thermostat??
    Mar 2012
    lakewood
    ive been running a 160 and it runs a bit rich but thats all i have noticed
  1. Thermostat?
    By Pure2sin in forum General Tech Discussion
    Last Post: 06-08-2011, 08:33 PM
  2. 180 degree thermostat
    By IGGYS 2008 GXP in forum 5.3L V8 (LS4)
    Last Post: 05-07-2009, 09:47 AM
  3. GTP Question New To The 90 Degree Motor
    By 05grndprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-27-2008, 08:15 PM
  4. 180 degree Tstat
    By bula81069 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2008, 02:05 PM
  5. 70+ Degree temps for 2 days and then roof falls in!!!
    By GeddyLee in forum Off Topic Discussion
    Last Post: 03-05-2008, 10:16 PM
