Thread: 160 or 180 degree thermostat??
Results 21 to 40 of 46
  1. #21 Re: 160 or 180 degree thermostat??
    stock the knock sensors don't turn on until 160* so a 160* thermostat could hurt your engine if your knock sensors aren't active.
  2. #22 Re: 160 or 180 degree thermostat??
    during the summer anyway it really doesn matter... its all about the fan settings usually... last year my stat went bad and I ran NO stat for about a month...
    steady 180-200 with no stat... winter would obviously be a different story though...
  3. #23 Re: 160 or 180 degree thermostat??
    Mar 2012
    lakewood
    The knock sensor kicks on past 160 because higher temps is when you get knock. Plus even though the stat is 160 doesn't mean tour engine is at 160, me operating temp is around 180-190
  4. #24 Re: 160 or 180 degree thermostat??
    Jeez you guys with my 180 thermo the hottest I got was 190*
  5. #25 Re: 160 or 180 degree thermostat??
    Out West
    Quote Originally Posted by thomas mcnulty View Post
    You can get knock when the engine is cold..
    Whine with your Cheese?
  6. #26 Re: 160 or 180 degree thermostat??
    Apr 2012
    nova
    was that with the stock gauge or with a scan tool/scanguage? I notice that my factory gauge reads different (lower) than my scan gauge..
    1999 gtp coupe... P&P heads, lim, and sc, comp vs cam, intake, dp and ubend
    2003 ford ranger fx4 level II- twin stick
  7. #27 Re: 160 or 180 degree thermostat??
    That was with my torque app. On my stock gauge it looks like its around 160* when its at 180*
  8. #28 Re: 160 or 180 degree thermostat??
    Jun 2011
    Sheboygan
    I run a 180 during the summer months, and put the 195 back in during the winter. My temp gauge does read cooler with the 180 tstat. I do it because of running the a/c during the summer to try and keep the engine cooler. Vice versa for the winter, the heater blows hot air sooner with the 195 tstat which allows the engine to heat up faster. Not a big deal to swap them, more of a peace of mind thing than anything.
    1998 Red 4 door GTP
    Ported & Polished S/C with a 3.4 zzp mps
    3" catted d/p from zz
    ZZP 1.0 PCM 180 T/S CAI AL 104s
  9. #29 Re: 160 or 180 degree thermostat??
    My heater blow plenty of hot air with a 180* in it. Within 2 miles of my house in the middle of winter i'm blowing heat.
    Quote Originally Posted by Cobras 98 Prix View Post
    How? Youll have heat with a 180 in the winter just as quickly.
  11. #31 Re: 160 or 180 degree thermostat??
    May 2008
    Winnipeg, MB
    who has noticed a decrease in their fuel mileage with the 180?
    2007 Pontiac Grand Prix
  12. #32 Re: 160 or 180 degree thermostat??
    Jan 2012
    Philadelphia
    Quote Originally Posted by tod1d View Post
    is it true i herd you get worse fuel mileage with a 180 in one of these threads
    curious because im gonna get a 180 soon
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    Mine sucked before and after the 180* tstat
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  14. #34 Re: 160 or 180 degree thermostat??
    Mar 2012
    lakewood
    I actually noticed my mileage got better...may have been the headers though
  15. #35 Re: 160 or 180 degree thermostat??
    Out West
    headers.
    flow improves mpg.
  16. #36 Re: 160 or 180 degree thermostat??
    didn notice crap with a lower stat OR egr delete...
  17. #37 Re: 160 or 180 degree thermostat??
    SE Level Member twiztid's Avatar
    Apr 2012
    Fort Wayne, IN
    Quote Originally Posted by gtpeddie View Post
    No, it's not true.
    Bryan
    2003 Regal GSX: 54k miles, TOG's, VS Cam, Gen V, HVTB
    2004 Regal LS: 75k miles, For Sale!
    1999 Regal GSX 12.86@108 - sold
  18. #38 Re: 160 or 180 degree thermostat??
    Quote Originally Posted by twiztid View Post
    No, it's not true.
    But it is.
  19. #39 Re: 160 or 180 degree thermostat??
    Apr 2011
    Vassar, Mi
    Mine had a 180 in it when I got it and I put it back in when I built the motor. Not a huge fan of it though, probably go back to stock if I ever have the tstat housing off again. The heat sucks in the winter compared to a stocker and it makes no noticeable difference in performance or tuning
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  20. #40 Re: 160 or 180 degree thermostat??
    I have a 180* thermostat and the heat will run you out. It blows more than enough heat in the winter and is blowing heat by the time I'm about 2 miles from my house. You must have other problems.
  1. Thermostat?
    By Pure2sin in forum General Tech Discussion
    Last Post: 06-08-2011, 08:33 PM
  2. 180 degree thermostat
    By IGGYS 2008 GXP in forum 5.3L V8 (LS4)
    Last Post: 05-07-2009, 09:47 AM
  3. GTP Question New To The 90 Degree Motor
    By 05grndprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-27-2008, 08:15 PM
  4. 180 degree Tstat
    By bula81069 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2008, 02:05 PM
  5. 70+ Degree temps for 2 days and then roof falls in!!!
    By GeddyLee in forum Off Topic Discussion
    Last Post: 03-05-2008, 10:16 PM
