Thread: Modding to 300 hp
Page 1 of 8 123 ... LastLast
Results 1 to 20 of 147
  1. #1 Modding to 300 hp
    SE Level Member MyPrixGT06's Avatar
    Weirton, WV
    I have a 2006 gt SC. I am going to started on my build and looking to get at or close to 300 hp at the crank (reason being I want to be as fast as the 5.3L). I am running an open cone as of now, thinking about building a CAI. Next on the todo list is headers. So, what 5hp for the intake and 15hp for the headers? That brings me to 280hp? If I follow the guide on "safely modding" to run a 3.6" pulley how much more hp could that give me or that else could I do to safely achieve my goal?
    2006 Pontiac Grand Prix GT-
    180 tstat and intake.
  2. #2 Re: Modding to 300 hp
    Jan 2012
    Philadelphia
    300 to the crank doesn't seem to hard to do
  3. #3 Re: Modding to 300 hp
    Out West
    2-3hp for the intake, 10-12hp for the headers stock
    Headers, 3.6MPS, 1.9 Rockers and #105 springs, and a good tune will get you 300 crank.
    Whine with your Cheese?
  4. #4 Re: Modding to 300 hp
    Texas
    300 crank is a very realistic goal. I would add 1.9 modded rockers and be done with it. With a solid tune that should net you damn close if not spot on. From there you could start dropping pulleys to push it even further.
    85 Corvette
    01 TA
    03 Z06
  5. #5 Re: Modding to 300 hp
    SE Level Member Mike Kopstain's Avatar
    Chicago, IL
    Agreed on the rockers. The 5.3 has a much stronger top end than the 3800 and 300hp on the 3800 isn't going to feel like 300 on the 5.3. Rockers will help that though.
    Thinking about shopping with ZZP or the other guys? - Order with us instead and we'll give you a 5% off coupon code for your next order! Click here to learn how!
    Like us on Facebook!
  6. #6 Re: Modding to 300 hp
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    id say open cone headers (proper spark plug heat range) 3.4'' pulley and a good tune should get you about 300BHP
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  7. #7 Re: Modding to 300 hp
    Out West
    It's not a 97-03, guy. 04+ will need to run real fat to push a 3.4 on just headers
  8. #8 Re: Modding to 300 hp
    Oct 2011
    Michigan
    ok whoops my bad i didnt read that part ok just change 3.4'' to 3.6'' and you should get a 300hp then i was thinking 97-03 thats what i have and thats my 300hp build
  9. #9 Re: Modding to 300 hp
    Banned
    CT
    300 is easy... it's over 300 where things start to get tough.
    mike, what do u mean the v8 has more 'top end'? I was always confused about what people mean by that.
  10. #10 Re: Modding to 300 hp
    Out West
    3800 is all low/mid end power, top end is nearly non existant without valvetrain mods
  11. #11 Re: Modding to 300 hp
    Banned
    CT
    But you need valvetrain mods to make 300bhp... even if it's just 1.9s, right?
  12. #12 Re: Modding to 300 hp
    Out West
    Rockers help but they don't nesc really change the way the car feels.
    Need a cam to really change that.
  13. #13 Re: Modding to 300 hp
    Topeka, KS
    Rockers and inter-cool it.
  14. #14 Re: Modding to 300 hp
    Chicago, IL
    Quote Originally Posted by SnowFlake View Post
    It doesn't fall on it's face in the upper rpm's like the 3800 does. Pit your average bolt-on modded 300 crank horsepower 3800 against against a Grand Prix GXP and the GXP will pull away every time.
    Generally not with the modded stock rockers but as the cars age it's definitely smart to change the valve springs.
  15. #15 Re: Modding to 300 hp
    Topeka, KS
    I changed the valve springs and seals while I was in there for my rockers.
  16. #16 Re: Modding to 300 hp
    Banned
    CT
    Quote Originally Posted by Mike Kopstain View Post
    I'm still confused, is this a gearing thing or a power curve type thing?
  17. #17 Re: Modding to 300 hp
    Out West
    Changed to beehive springs with my setup
  18. #18 Re: Modding to 300 hp
    Out West
    Power curve due to the cam.
  19. #19 Re: Modding to 300 hp
    Topeka, KS
    There's no replacement for displacement
  20. #20 Re: Modding to 300 hp
    Banned
    CT
    Quote Originally Posted by Nixon View Post
    So what you guys are saying is that if we compared a mild bolt on gp with 1.9s that makes the same whp as a stock LS4 that the LS4 will make it's peak tq and peak hp higher in the RPM range relative to the L67 and it will carry decisively more power into the redline?
    Am I on the right track?
  1. Modding
    By Axadas in forum General Grand Prix Discussion
    Last Post: 03-11-2012, 04:40 PM
  2. on my way modding
    By jspangler22 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2011, 10:03 PM
  3. help with modding
    By sdenton8 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2011, 11:02 PM
  4. Modding 08 GP GT..
    By 08GrandPrixV6 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-21-2009, 09:57 PM
  5. Modding my GTP
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2009, 08:26 PM
