Thread: Best Ways to add power to GTP
Results 1 to 9 of 9
  1. #1 Best Ways to add power to GTP
    May 2012
    Bowman, Ga
    I have a 1997 Pontiac Grand Prix GTP. I'm looking for best ways to add horsepower torque everything. Cheaper the better but would like to know all options. Ive heard bout changing pulleys on the supercharger and stuff but would like more info.
    Car has CAI and Aftermarket Air Filter
  2. #2 Re: Best Ways to add power to GTP
    Donating User Odi's Avatar
    Chicago South Suburbs
  3. #3 Re: Best Ways to add power to GTP
    GTX Level Member crbquist's Avatar
    Massachusetts
    One word: cam
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  4. #4 Re: Best Ways to add power to GTP
    Feb 2009
    flintnasty MI
    Turbo is cheapest and easiest for biggest gains
  5. #5 Re: Best Ways to add power to GTP
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    just read the link above, it tells you alot
  6. #6 Re: Best Ways to add power to GTP
    Yeah you want the most power per dollar go turbo. Otherwise headers pulley tune be about $400-$450.
  7. #7 Re: Best Ways to add power to GTP
    Dec 2011
    Philadelphia, PA
    Quote Originally Posted by slick2500 View Post
    more then that if he doesnt install the headers by himself
    AEM bruteforce intake
    Diablo 93 Octane tune
  8. #8 Re: Best Ways to add power to GTP
  9. #9 Re: Best Ways to add power to GTP
    Best thing you can SERIOUSLY do...
    Take care of the weak spots...
    The Lower Mounts, Exhaust, and the Transmission.
    Flip the upper dog bone mounts for free, get solid rubber motor/transmission mounts, Headers..shift kit...pan drop...new filter/fluid; not a flush though.
    Since you already have an intake setup...I'd do a tune-up if you haven't...plugs/wires/oil/coolant flush/180* T-stat/PCV/fuel filter...check axles/hubs/brakes...etc.
    Then after all that...a PCM tune and a pulley drop...that should be good for a solid 40~ WHP over stock.
  1. Different ways to scan
    By RamonGTX in forum Off Topic Discussion
    Last Post: 06-02-2011, 07:19 PM
  2. Cheap ways to make alot more power on a GT
    By intervention in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-18-2009, 01:24 AM
  3. Best ways to launch?
    By putskijr in forum Off Topic Discussion
    Last Post: 09-16-2009, 06:10 PM
  4. Inexpensive ways to do this?
    By BwolfGT in forum Visual/Body Modifications
    Last Post: 08-30-2009, 12:12 PM
  5. Parting ways with the Monte.
    By 7801MonteMan in forum Off Topic Discussion
    Last Post: 05-28-2008, 11:52 AM
