Thread: Oil Level??
Results 1 to 9 of 9
  1. #1 Oil Level??
    Aug 2008
    SOUTH TEXAS
    I had my motor oil changed yesterday, now question.
    If i remmember right, it takes 4.5 quarts of motor oil???
    Cause, the dude poured 5 quarts, now its a little over the full line on the dip stick.
    Is it going to be a problem??
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
    Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
  2. #2 Re: Oil Level??
    Jul 2008
    Poteau Oklahoma
    no problem at all.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  3. #3 Re: Oil Level??
    Aug 2008
    SOUTH TEXAS
    So is it 4.5 or 5 quarts of oil???
  4. #4 Re: Oil Level??
    PA
    It is 4.5 quarts to full. The extra .5 quart won't hurt you a bit. And is good cause your engine will use a little.
    Don't worry about it.
    2001 GSE
  5. #5 Re: Oil Level??
    Oklahoma
    I intentionally overfill mine a bit past the full mark and have done so on many vehicles over time with no ill effects. You got maybe about a .5 quart or so of play there and about .5qt would be about I would overfill anyway.
  6. #6 Re: Oil Level??
    Barksdale AFB, LA
    As long as it isn't way over the full line. If that happens, it can cause leaks at the main seals, can touch the crank and get churned to a froth, let the froth get sucked up and doesn't lubricate as well, and I think you can guess the outcome.
    A bit past is fine; a lot past is no good.
    2009 Subaru Impreza WRX STI
  7. #7 Re: Oil Level??
    Aug 2008
    SOUTH TEXAS
    All right, thanx guys!!!
  8. #8 Re: Oil Level??
    Oklahoma
    Quote Originally Posted by Sabrewings View Post
    That really already occurs when the oil is filled normally. Its called a windage cloud and, a trick used by old school racers and still used today, to reduce that cloud and reclaim the horsepower it steals is to use crank scrapers.
    Ive seen some for the Series I 3800, but have not seen any for the Series II & III engines. I contacted a guy that makes them a long time ago to see if he would make a set for the Series II. He was very willing to do so but needed a Series II bottom end to get the fitment right.
  9. #9 Re: Oil Level??
    Banned
    Wichita Falls, Texas
    I always put a full 5 quarts in when I change the oil, no big deal at all.
  1. Finally no longer SE Level!!
    By GeddyLee in forum Off Topic Discussion
    Last Post: 04-30-2010, 09:47 AM
  2. oil level low
    By johnnyj773 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-07-2008, 03:10 AM
  3. GTP Level member
    By IndeedSS in forum Off Topic Discussion
    Last Post: 03-10-2008, 10:16 PM
  4. What Entry Level Struts?
    By RNUOVR in forum Brakes/Suspension/Chassis
    Last Post: 01-15-2008, 09:07 AM
  5. Oil Level Sender Thread
    By Speeder in forum Turbo
    Last Post: 01-08-2008, 09:25 PM
