Thread: misfires after cam install
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
  1. #1 misfires after cam install
    Lima, OH
    Well I just install an XP cam. When I started the car up and leave it idle the RPMs will jump up all of a sudden and back down then it will idle. It do this repeatedly. I have checked for vacuum leaks repeatedly and found nothing. I even took the supercharger back of and siliconed the gasket and it will still do it. I did a compression test and every cylinder is within +/-10 of 160psi. Someone else said I should be using 103s instead of the 104s. The plugs are lapped .060 and I'm using PRJ wires. My current mods is Gen5, 3.4mps, XP cam, TOGs with cat-less down pipe, custom ported head with matching ported LIM, 180* drilled thermostat, and 42.5lb injectors. I'm at a lost to what causing this but I am see some mist coming from my exhaust but I don't know if that's normal for a cat-less exhaust system or not?
    1/8mile: 9.354sec@77.026mph the best 60ft: 2.211sec
    1/4mile: 14.2889sec@93.16mph the best 60ft: 1.9668sec
  2. #2 Re: misfires after cam install
    you double check the plug wires are on right?
  3. #3 Re: misfires after cam install
    Apr 2009
    Fort Worth TX
    A 3.4 with a GEN V? Holy crap Batman!
  4. #4 Re: misfires after cam install
    Mercer, Pa
    Plug in a code reader and tell us the codes if you have any. Are you getting misfires and if so on what cylinders.
    Is the only thing you changed the cam, you already had the gen 5 and other mods on the car and running.
  5. #5 Re: misfires after cam install
    Lima, OH
    Quote Originally Posted by Rico View Post
    I should be able to run a 3.2 or push it a little bit and run a 3.0 pulley but the biggest pulley that I had at the time was a 3.4 pulley. I know I got the plug wires on each cylinder rite but on each ignition coil Idk I will have to look when I get back into town. I have an aeroforce gauge but its saying I have 0 misfires but I can go to the back of my car and hear it misfire out the end of my exhaust.
  6. #6 Re: misfires after cam install
    maybe your just hearing the cam?
  7. #7 Re: misfires after cam install
    Mercer, Pa
    Quote Originally Posted by gtptim View Post
    I'd stick with the 3.4. Headers and cam don't equal 3.0 in gen 5.
    Your getting no codes?
  8. #8 Re: misfires after cam install
    .060 plug gap is HUGE
    Step it down to .050 atleast
  9. #9 Re: misfires after cam install
    Ohio
    this^^^^^
  10. #10 Re: misfires after cam install
    Feb 2009
    flintnasty MI
    at idle, too small of a gap will cause misfires... And that being said IDK how mine even runs it misfires at idle so bad.
    as far as the idle surging... many things cause that, usually its tuning related and considering you changed like everything... uhh.
  11. #11 Re: misfires after cam install
    Lima, OH
    Quote Originally Posted by sseilmnop View Post
    How do you figure that? I dont read no mention of ported heads in the quote from you. I do have 2 codes coming up on my aeroforce gauge but there from my EGR valve which I deleted the EGR just didnt delete them from the PCM. Yes the plug wires on everything is correct.
    Mercer, Pa
    Not sure how to gauge custom ported heads. If you can run 3.0 with no knock great. I think you will end up bigger.
  13. #13 Re: misfires after cam install
    Lima, OH
    They out flowed ZZP stage3 heads
  14. #14 Re: misfires after cam install
    Apr 2009
    Fort Worth TX
    O_o
    How do you know this? Did ZZP put them on their flow bench?
  15. #15 Re: misfires after cam install
    Lima, OH
    O_o
    The guy that did the head work also flow tested a set of ZZP stage3 and then mine.
  16. #16 Re: misfires after cam install
    Apr 2009
    Fort Worth TX
    Are they L67 or L32 heads? Is the custom ported intake Gen V or Gen III?
  17. #17 Re: misfires after cam install
    Did you remove the P0300, it needs to be taken out.
  18. #18 Re: misfires after cam install
    Quincy, Mass
    103s would be too cold. Gap should be more like .053-.055
    a 3.4 on a gen V equals a 3.2 on a gen 3
    No more GP 04 Impala SS Indy:
  19. #19 Re: misfires after cam install
    GT Level Member afallucco's Avatar
    Ohio
    3.5 runs pretty good too
    Gen V can be fun, clayton is running a 3.4 on his gen V with an s1x cam and derek with his vs. Gonna advance my timing and retune to see what I can pull with the 3.5 and then drop it down to a 3.4 and retune depending on my injectors.
    2004 Grand Prix GTP
    |FWI | HP Tuner | 1.9 Rockers | SD Headers | 3.5MPS | 97-03 control arms w/GMPP sway bar|
    Planned soon: s3x, custom ported heads, IC
    Thug life, that's how we live.
  20. #20 Re: misfires after cam install
    Lima, OH
    They are L67 heads and the LIM is a Gen5.
  1. car misfires
    By backinblackgtp in forum Engine
    Last Post: 03-24-2011, 03:25 PM
  2. Replies: 18
    Last Post: 03-24-2011, 02:07 AM
  3. Misfires in Cyl 4
    By mousemonster1232 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2011, 02:38 PM
  4. misfires??
    By paulaxe in forum Engine
    Last Post: 11-23-2010, 04:09 PM
  5. WOT misfires
    Last Post: 11-12-2008, 08:58 PM
