Thread: Nitrous on a GTP
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
  1. #1 Nitrous on a GTP
    GT Level Member lilrocket's Avatar
    landis,nc
    on here we go as of now we have a gen v, s2 inter-cooler, 1.9 roller rockers, 105 spring, cia, aeromotive stealth pump, zzp pcm, 42.5lb injectors, mps with a 3.4, 3.2, 3.0, 2.8 which im running currently with no problems loving it could other mods like machined lim etc. i have a nos wet system on the car now went from a 50 to 75 then to a 100 and i just purchased a nitorus controller bc the car starts to spin bc the nitrous is on a wot switch and at full boost all it does is spin for about 30ft or so then goes how much nitrous has anyone ran on the stock bottom end and had good results i figured with the controller i could go on up the the 125 or 150 and just progress it in so that it doesn't try to blow the tires off anyone have any details
    98 DAYTONA 1110/1500: work in progress
    00 DAYTONA 216/2000: totaled but not forgotten parts car
    "Speed its my drug, the faster i go, the faster i want to go!"
  2. #2 Re: Nitrous on a GTP
    You really are trying to blow that thing up arn't you?
    SMGPFC Member #10
  3. #3 Re: Nitrous on a GTP
    You're running all four pullies at once? Kewl.
    Traction issues?
    Get slicks.
  4. #4 Re: Nitrous on a GTP
    landis,nc
    slicks suck for everyday driving lol i have 275-40-17 nitto drag radials now at 20 psi still spins about 30 foot or so, im running a 2.8 right now lol all pulleys at once i guess ill swap all the pulleys out and run smaller all the way around, i dont wont to blow it up but ill have the nic cam in about 2 weeks so if it does well build her back up
  5. #5 Re: Nitrous on a GTP
    your intercooled and gonna run a nic cam?
  6. #6 Re: Nitrous on a GTP
    Quote Originally Posted by lilrocket View Post
    Guy, its called FWD. Get used to spinning.
  7. #7 Re: Nitrous on a GTP
    landis,nc
    fug that im gonna progress the nitrous in instead of using the wot switch just trying to see whats the most anyone has tryed
    yea the nic cam with a intercooler why not if i run the nic cam which had a lift of 507 with 1.6 rocker ill be beack up around 520's or so bc im still gonna run the 1.8 roller rockers i have so ill have higher lift than the xp and xpz and keep desend vacuum for everyday driving bc of the brakes
  8. #8 Re: Nitrous on a GTP
    youre running a 2.8 on a genV? are you scanning? Id like to see that scan...
  9. #9 Re: Nitrous on a GTP
    Apr 2012
    nova
    When it blows I call dibs on the s2 intercooler
    1999 gtp coupe... P&P heads, lim, and sc, comp vs cam, intake, dp and ubend
    2003 ford ranger fx4 level II- twin stick
  10. #10 Re: Nitrous on a GTP
    landis,nc
    yeap 2.8 on a gen v and she screams with 16* of timing a pulls like a mofo
  11. #11 Re: Nitrous on a GTP
    scan?
  12. #12 Re: Nitrous on a GTP
    landis,nc
    i do scan it lol
  13. #13 Re: Nitrous on a GTP
    no do you HAVE a scan of it?
    how much is your max boost?
  14. #14 Re: Nitrous on a GTP
    Sep 2011
    MI
    Isn't it awsome when you ask a question, and all people do is pick apart your current mod list? Happens ALL the time. Makes em feel like a Boss... Feckin trolls!
    Anywhoo... If I could offer any insite I would. I've not messed with Nitrous myself. So, best of luck!
  15. #15 Re: Nitrous on a GTP
    Quote Originally Posted by 99PontiacGTP View Post
    isn it awesome when people who have no clue what they are talking about make a totally pointless post on your thread? makes "em" look like a douche...
    rocket, believe it or not I am trying to help you here if you have a scan I could look at... without one it is gonna be hard to give you a good answer...
  16. #16 Re: Nitrous on a GTP
    landis,nc
    max boost with the 2.8 is 12psi with the ported lower manifold and the s2 ic, the air fuel off nitrous is 10.6 and the air fuel spraying it is at 11.2 scaning the air fuel with a dyno jet wideband, KR is at 1.5 untill you hit wot has the 1.5 kr during mild accesleration do to the motor torquing, the car does have headers, full 2.5 exhaust turbin mufflers so pretty much straight through, and the heads are all gasket matched what else would you like to know i see you sig. ill put up some cash to show you how slow she is oh with my dryer duct cia
  17. #17 Re: Nitrous on a GTP
    landis,nc
    heres a better one a lil cleaner
  18. #18 Re: Nitrous on a GTP
    The Boss Iceman6669's Avatar
    Jun 2011
    Nice ride... Not to get off topic but what do you run in the 1/4?
    2011 F-150 Yote powered
    Ohio
    Ohhh you're the gai cole has been pic whoring on Facebook hahaha
  20. #20 Re: Nitrous on a GTP
    landis,nc
    my scan tool is a nemisys obd2 pretty much tells you anything you would like to know from transmission shifting, miss fire history, kr injector pulse widths you name it she can read it what part of the scan are you interested in the scan only logs while the car is running so kinda a buzz kill were putting it on hp tuners and dynoing it in the next couple weeks just tryin to figure the nitrous out before hand really would like to see how fare people have pushed them
  1. nitrous
    By Brennan73 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2011, 10:33 AM
  2. Nitrous?
    By MoBoost in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2011, 02:43 PM
  3. How much nitrous can be ran?
    By basshead42 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-18-2009, 06:05 PM
  4. Nitrous, Dry or Wet?
    By japslpr in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2009, 02:32 PM
