Thread: Question about L32 crank case pressure
Results 1 to 3 of 3
  1. #1 Question about L32 crank case pressure
    Ok people as most of you know I did the full L32 swap but retained my L67 throttle body. I know you can tap the top of the throttle body where that plug is and run a vacuum line to the back of the Gen 5 SC to help aid the vacuum pressure. I'm wondering what size thread tap and die sets people are using. The reason I ask is because I blew the dip stick right out of the tube and got oil all over my engine.
    Snorlax strikes again.
  2. #2 Re: Question about L32 crank case pressure
    Ohio
    i know its a 1/4 npt.. that should be enough for you
  3. #3 Re: Question about L32 crank case pressure
    Ohio
    you got it..
  1. Supercharger case question
    By shawnschuldt in forum General Tech Discussion
    Last Post: 05-02-2011, 08:05 AM
  2. How do you perform a crank case relearn?
    By GOTIT4CHEAP16 in forum PCM Tuning
    Last Post: 08-16-2010, 06:28 AM
  3. Replies: 6
    Last Post: 04-19-2009, 12:49 PM
  4. fuel pressure question
    By jdevier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2008, 11:35 AM
  5. question: eletric oil pressure
    By fst in forum General Tech Discussion
    Last Post: 06-23-2008, 09:21 PM
