Thread: ses light for multiple cylinder misfire help!!!
Results 1 to 12 of 12
  1. #1 ses light for multiple cylinder misfire help!!!
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    i drive a 97 gtp that has 161k miles on it and i changed the plugs to ngk tr551x's and changed the coil packs and the plug wires. i have cleared the code many time it keeps coming back and i cant seem to find whats causing the ses light can anyone help
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: ses light for multiple cylinder misfire help!!!
    I would start with checking the things in this list, you already changed plugs and wires so you can start with the front o2 sensor.
    My car has this same problem and I've changed everything but checking the valves and changing the pcm in my car and it still misfires.
    A code P0300 may mean that one or more of the following has happened:
    • Faulty spark plugs or wires
    • Faulty coil (pack)
    • Faulty oxygen sensor(s)
    • Faulty fuel injector(s)
    • Burned exhaust valve
    • Faulty catalytic converter(s)
    • Stuck/blocked EGR valve / passages
    • Faulty camshaft position sensor
    • Defective computer
  3. #3 Re: ses light for multiple cylinder misfire help!!!
    Troy OH
    aren't those plugs three heat ranges colder than what you should be running?
    edit: nevermind. but they're recommended for naturally aspirated cars. are you modded? sure you got everything hooked up right? right firing order?
  4. #4 Re: ses light for multiple cylinder misfire help!!!
    Kemmerer, Wyoming
    are the plugs gapped right?
  5. #5 Re: ses light for multiple cylinder misfire help!!!
    Troy OH
    you're not really supposed to gap iridium
  6. #6 Re: ses light for multiple cylinder misfire help!!!
    Sep 2011
    palm harbor florida
    ya my car doesnt skip a beat but i keep getting the ses lights and ive heard that autolites 605's would be good.
    Does the ses light flash when driving down the highway?
    Sent from my ADR8995 using Tapatalk 2
  8. #8 Re: ses light for multiple cylinder misfire help!!!
    Sep 2011
    palm harbor florida
    ya sometimes it stays solid and others it will flash
  9. #9 Re: ses light for multiple cylinder misfire help!!!
    Yeah thats not good.
    My car had about the same amount of miles on it when I got it. Thats how mine started the SES light started flashing at me and I just had random misfire cylinder #1, I could reset the code drive around in town for days and no SES light, but as soon as I got on the highway it would kick on after a few miles and would flash randomly. I replaced plugs, wires, icm, coils, injector o rings, harmonic balancer, crank and cam sensor and still had a misfire, then it turned into multiple random misfires. Scanning with Torque showed that most of the misfires were cylinders 1, 2 &3. I decided one day to tear apart the top of my engine and what did I find. My guess is that the piston was already chipped when I got the car and things just got worse as time went by. Before you start tearing apart your engine have you checked the ICM to ensure that it is good? Have you checked for vacuum leaks? Have you given your car a seafoam treatment?
  10. #10 Re: ses light for multiple cylinder misfire help!!!
    Sep 2011
    palm harbor florida
    damn that is not what i want to hear lol. I've replace everything you have including the icm the only sea foam i have used goes into your gas tank and a little into the oil to break down carbon build up. My car also has a couple of ticking noises but i think that might be a stick lifter or something. What did you use to scan your car to see where the misfires are happening. And also before i got my car whoever had it before my grandfather beat the crap out of it and it barely started and me and my dad brought it back to life when my grandpa gave it to me for my 16th birthday.
    I used Torque on my phone. And if the previous owner beat the crap out of it I would see if you can't buy or rent a borescope and look in the cylinders through the plug holes. I'm guessing you have a chipped piston.
  12. #12 Re: ses light for multiple cylinder misfire help!!!
    Sep 2011
    palm harbor florida
    what are my options if i have lets say 2 chipped pistons. 1. replace the bad pistions. 2 replace all the pistons and bearings 3. get a new motor. im leaning towards the second option
  1. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  2. Cylinder #3 Misfire - SES Light Flashing
    By pc305577 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-18-2009, 03:01 PM
  3. 1999 GTP 3.8L SC Cylinder Misfire SES Light Flashing
    By pc305577 in forum Introductions/Noob Questions
    Last Post: 08-18-2009, 07:46 PM
  4. Random multiple cylinder misfire
    By sunfiregtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2009, 08:58 PM
  5. P0300 multiple cylinder misfire code
    By Reeddawgy in forum PCM Tuning
    Last Post: 07-15-2008, 07:42 PM
