Thread: CEL problem codes, P0102, P0300, P1381 and a few more UPDATED!
Results 1 to 20 of 20
  1. #1 CEL problem codes, P0102, P0300, P1381 and a few more UPDATED!
    GTP Level Member buickman104's Avatar
    NYC
    Yesterday when driving to my girlfriend's home I suddenly got a check engine light. I looked up the codes on my Aeroforce and got these 3 codes.
    I know the P0102 is a MAF code. I'll try cleaning it.
    The P0300 is a multiple misfire code. Ned to get my ignition checked out again.
    The P1381 code I have no idea. On different models it means different things. Any suggestions?
    I also wonder why I would get all these codes simultaneously?
    After I parked my car and came back to it 10 hours later the check engine light was gone. Might be gone for now, but I would rather figure these problems out now before they grow.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  2. #2 Re: CEL problem codes, P0102, P0300, P1381
    how old are the plugs and wires?
  3. #3 Re: CEL problem codes, P0102, P0300, P1381
    Apr 2009
    Fort Worth TX
    The PCM uses data from the ABS to distinguish crankshaft speed variations from actual misfires p0300. If there is a loss of communication from the wheel speed sensors while P0300 has set a MIL then P1381 will set.
  4. #4 Re: CEL problem codes, P0102, P0300, P1381
    NYC
    Quote Originally Posted by Rico View Post
    Does that mean my crank sensor might be bad?
    plugs are Autolite104's with 5,000 miles on them and wires are PRJ with 15,000 miles. All my coil packs are new and a junkyard ICM because my last one went bad.
  5. #5 Re: CEL problem codes, P0102, P0300, P1381
    Apr 2009
    Fort Worth TX
    To be quiet honest I think the code (P1381) may be a fluke in your situation. Clean the MAF, run it and see what happens before you come to any conclusions.
  6. #6 Re: CEL problem codes, P0102, P0300, P1381
    NYC
    Got the same combination of CEL again. This time the engine is heavily hesitating.
  7. #7 Re: CEL problem codes, P0102, P0300, P1381
    Apr 2009
    Fort Worth TX
    Have you cleaned/replaced the MAF yet?
  8. #8 Re: CEL problem codes, P0102, P0300, P1381
    NYC
    I've cleaned it and currently looking for a replacement. could all this be caused by a bad maf?
  9. #9 Re: CEL problem codes, P0102, P0300, P1381
    Apr 2009
    Fort Worth TX
    Yep
  10. #10 Re: CEL problem codes, P0102, P0300, P1381
    NYC
    Got a good MAF from a local on NYMCGP. It worked wonderfully. Killed all my KR and I was now getting 15 degrees of timing. Last night I was driving home and the check engine light came on and now got a new medley of codes...
    P0102- MAF code AGAIN!
    P0243- Seems like a BBV malfunction code. Correct me if I am wrong.
    P0300- Mulitiple missfire- I have noticed I only get light miss fires at idle when warming the engine up. Never seen miss fires while actually driving.
    P0443- Evap Code. That's new
    I am wondering why I am getting all these codes in one shot. I am starting to suspect that maybe something might be wrong with my wiring harness. IDK anymore.
  11. #11 Re: CEL problem codes, P0102, P0300, P1381 and a few more UPDATED!
    Check the pcm connections. Also the electrical connector for the maf. Scottdogger is the resisdent expert that tells us about the wires getting old and brittle over the exhaust. Your's are likely worse than most considering the under hood temps in your city car.
  12. #12 Re: CEL problem codes, P0102, P0300, P1381 and a few more UPDATED!
    NYC
    That is true. That is what I was thinking too.
    Also if you remember Bill, my Maf pigtail has been changed before.
  13. #13 Re: CEL problem codes, P0102, P0300, P1381 and a few more UPDATED!
    All I remember is you left a large hunk of aluminum at my place.
  14. #14 Re: CEL problem codes, P0102, P0300, P1381 and a few more UPDATED!
    NYC
    Mind shipping that hunk of aluminum with one of your spare lq 4 mafs for 50$ plus shipping? :-P
  15. #15 Re: CEL problem codes, P0102, P0300, P1381 and a few more UPDATED!
    NYC
    Checked my issue out with Enrique today. Definitely seems like an electrical problem. My boost bypass, evap, and maf seem to all be dead. Tried another maf and still nothing. For you wiring experts is there a common ground between those sensors or does anyone have a wiring harness schematic to help us make sense out of what could be wrong.
  16. #16 Re: CEL problem codes, P0102, P0300, P1381 and a few more UPDATED!
    Apr 2009
    Fort Worth TX
    Here are some ground references:
  17. #17 Re: CEL problem codes, P0102, P0300, P1381 and a few more UPDATED!
    NYC
    Went over the wiring today with a multi-meter. The pigtails to each of those sensors show no voltage. I checked other sensor pig tails and they were all fine. Tomorrow morning i plan on checking for blown fuses.
  18. #18 Re: CEL problem codes, P0102, P0300, P1381 and a few more UPDATED!
    NYC
    Got a test light and it turned out to be a blown ignition 1 15amp fuse. Changed fuse and problem solved!
  19. #19 Re: CEL problem codes, P0102, P0300, P1381 and a few more UPDATED!
    Apr 2009
    Fort Worth TX
    Good thread
    Glad you got it figured out.
  20. #20 Re: CEL problem codes, P0102, P0300, P1381 and a few more UPDATED!
    NYC
    Thanks rico, your wiring diagram helped.
  1. Serious problem codes and freeze frame
    By kyleinkman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2011, 02:51 PM
  2. ABS/Traction control problem with scanner codes
    By ptnothere in forum Brakes/Suspension/Chassis
    Last Post: 04-12-2011, 11:08 PM
  3. Bad idle and RPM issues not to forget codes P0303, P0341, AND P0300
    By jessiinicole in forum Off Topic Discussion
    Last Post: 03-08-2010, 02:27 PM
  4. SES error codes P0102, P1404
    By camcavoy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2009, 09:56 AM
  5. PLEASE HELP! Codes P0102 & P0452
    By TAWinner23 in forum General Tech Discussion
    Last Post: 09-17-2008, 02:11 PM
