I tried to see when my car cuts out and it doesn't... What is the speed limited to on an '04 GTP... I haven't put an aftermarket PCM in it yet... I'm confused...![]()
And... just exactly how fast did you get up to?
nah mine does about 125mph @ 2800 RPM's (obviously 4th gear lol)....erm then it cuts back/off or whatever.
There are other things that will effect the cutoff, but the max speed set in the PCM is 150. There are injector cutoff limits lower, though.
Picture is worth a thousand words.
yep good SS
not sure, like i said mine is set at 125
In Ontario you lose your car at 50k over the limit which is 95 mph. Thats right, lose your car for 1 week and minimum $2000-$10,000 fine. I rate a car form 0-150km as it is expensive after that.
