Thread: EVAP Canister
Results 1 to 15 of 15
  1. #1 EVAP Canister
    Mar 2012
    Hays, KS
    On the evap canister the round clip end connects to it where does the other end with the 90 deg rubber boot go?
    Quincy, Mass
    What year is your car?
    No more GP 04 Impala SS Indy:
  3. #3 Re: EVAP Canister
    Mar 2012
    Hays, KS
  4. #4 Re: EVAP Canister
    Mar 2012
    michigan
    one line goes to evap with the fiting on it the other goes to the fron sid eof your throttle body
  5. #5 Re: EVAP Canister
    Mar 2012
    Hays, KS
    What if i have done the gen v swap and have a northstar throttle body
    Quincy, Mass
    The vac port on the N* connects to the nipple by the genV evap on the supercharger
  7. #7 Re: EVAP Canister
    Mar 2012
    Hays, KS
    Using the hose with the round clip and the 90 deg. boot on the other end? the round clip end has only one spot it goes to the evap canister. am i making any sense? i didn't look real close on the northstar but there should be a vac port for sure?
    Quincy, Mass
    Yes there is a small metal tube the comes out tb in the side the cables go on. That elbow would go in the intake tubing on the stock 04+ air intake if it's the same vac line I'm thinking of. Can you post some pics of the line your talking about?
  9. #9 Re: EVAP Canister
    Mar 2012
    Hays, KS
    It's the vacuum line coming off the evap canister purge valve on one side is the end that connects to the evap the vacuum hose is kinda of a pre bent shaped hard plastic
  10. #10 Re: EVAP Canister
    Portland Oregon
    Just hook it up to a vacuum source. Doesn't matter where. Hell, doesn't even have to be a source of vacuum, just plumb it into the intake near the TB if you can
  11. #11 Re: EVAP Canister
    Portland Oregon
    Or pull it, cap it, and delete the code.
  12. #12 Re: EVAP Canister
    Mar 2012
    Hays, KS
    I was looking for a vacuum port on my Northstar and didn't find one. If i have evap delete on my pcm then i can just remove the hose and cap off the end on the evap canister purge valve right?!
  13. #13 Re: EVAP Canister
    Mar 2012
    Hays, KS
    I've been researching more on this the line...it is supposed to go from the evap purge valve to the throttle body but i do not see the place to connect it on the Northstar
  14. #14 Re: EVAP Canister
    Quincy, Mass
    if your N* looks like this one then its an 00+ N* and the vac source is circled in red
  15. #15 Re: EVAP Canister
    Mar 2012
    Hays, KS
    Mine doesn't have the fitting tho...
  1. EVAP canister solenoid?
    By Pure2sin in forum General Tech Discussion
    Last Post: 07-19-2012, 11:33 PM
  2. EVAP canister purge valve vacuum line part number
    By Freimuth in forum General Tech Discussion
    Last Post: 04-18-2012, 11:00 AM
  3. Car smells of gas when stopped, net said charcoal canister??
    By blbikerood in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-01-2011, 11:36 AM
  4. 04 gtp canister fit in an 01 GT?
    By ChrisGTT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2010, 05:23 PM
