On the evap canister the round clip end connects to it where does the other end with the 90 deg rubber boot go?
1999
one line goes to evap with the fiting on it the other goes to the fron sid eof your throttle body
What if i have done the gen v swap and have a northstar throttle body
The vac port on the N* connects to the nipple by the genV evap on the supercharger
Using the hose with the round clip and the 90 deg. boot on the other end? the round clip end has only one spot it goes to the evap canister. am i making any sense? i didn't look real close on the northstar but there should be a vac port for sure?
Yes there is a small metal tube the comes out tb in the side the cables go on. That elbow would go in the intake tubing on the stock 04+ air intake if it's the same vac line I'm thinking of. Can you post some pics of the line your talking about?
It's the vacuum line coming off the evap canister purge valve on one side is the end that connects to the evap the vacuum hose is kinda of a pre bent shaped hard plastic
Just hook it up to a vacuum source. Doesn't matter where. Hell, doesn't even have to be a source of vacuum, just plumb it into the intake near the TB if you can
I was looking for a vacuum port on my Northstar and didn't find one. If i have evap delete on my pcm then i can just remove the hose and cap off the end on the evap canister purge valve right?!
I've been researching more on this the line...it is supposed to go from the evap purge valve to the throttle body but i do not see the place to connect it on the Northstar
if your N* looks like this one then its an 00+ N* and the vac source is circled in red
Mine doesn't have the fitting tho...
