Thread: Harmonic Balancer Bolt Removal
Results 1 to 20 of 34
  1. #1 Harmonic Balancer Bolt Removal
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    How long did you guys have to go at it with the impact to get it off? Ive been at it off an on for like half an hour and it seems to be happy where its at.
    Any ideas on how to get that bolt off before I go redneck on that thing!!!
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  2. #2 Re: Harmonic Balancer Bolt Removal
    Mercer, Pa
    Unless you have a really good impact, which i dont, it wont break loose. Try spraying some oil in impact air fitting and getting the compressor up to max pressure before you start.
  3. #3 Re: Harmonic Balancer Bolt Removal
    Marysville WA
    Quote Originally Posted by sseilmnop View Post
    Thanks ill try that, I got her all buttoned up for the night gonna go at it again tomorrow. Need to replace that CPS and man is it a pain in the ass. Have you ever had to break it loose with the redneck method?
  4. #4 Re: Harmonic Balancer Bolt Removal
    Apr 2009
    Fort Worth TX
    Impacts are for sissys. I just lock the motor back at the flexplate and use a 2 foot breaker bar. When they break it makes a loud pop...I love it. It's good exercise.
    Mercer, Pa
    My last motor the timing chain broke and junked the valves at 183k. I broke it loose by putting rod in spark plug hole and a really long breaker bar. block was already junk but i don't recommend that for good block/piston.
  6. #6 Re: Harmonic Balancer Bolt Removal
    Apr 2009
    Fort Worth TX
    I've seen people fill one of the cylinders with oil...same principle.
  7. #7 Re: Harmonic Balancer Bolt Removal
    Marysville WA
    Gonna try locking it at the flex plate tomorrow and use the breaker and hopefully that will do the trick!
    Jan 2009
    Tallahassee, FL
    I got mine off by locking the flexplate as well, vice grips do the trick.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  9. #9 Re: Harmonic Balancer Bolt Removal
    SE Level Member Agentlongwood's Avatar
    Nov 2009
    Orlando
    I've seen people rest the wrench/breaker bar against a piece of frame and turn the key to start for a second. Let the motor do the work lol
  10. #10 Re: Harmonic Balancer Bolt Removal
    Mar 2012
    Minnesota
    Well if you've got the money buy a snap on super duty impact or an ingersol rand impact. Or get out the eight foot breaker. Either work nicely.
  11. #11 Re: Harmonic Balancer Bolt Removal
    Nov 2011
    Bayamon, Puerto Rico, Puerto Rico
    Youtube starter trick works flawlessly!
  12. #12 Re: Harmonic Balancer Bolt Removal
    While you already have the balancer off I would check the condition of it.
  13. #13 Re: Harmonic Balancer Bolt Removal
    i've always had a good impact to use so i never had any issues. zip it off, zip it on. presto magico.
  14. #14 Re: Harmonic Balancer Bolt Removal
    Marysville WA
    I am gonna try locking it at the flex plate, I have a five gallon trades pro compressor
    AlltradeTools - Catalog - 835486 5 Gallon Twin Tank Air Compressor - Reconditioned
    And this set, I think its starter gear but not sure if its good enough to break the balancer bolt.
    AlltradeTools - Catalog - 830228 71 Piece Air Tool Set
  15. #15 Re: Harmonic Balancer Bolt Removal
    Quote Originally Posted by Agentlongwood View Post
    This ^^^^ Works great. It'll save you a lot of trouble.
  16. #16 Re: Harmonic Balancer Bolt Removal
    Marysville WA
    Have you done it before? And if you did did you disable the ignition system?
    Quincy, Mass
    FYI you can reuse the stock bolt.
    No more GP 04 Impala SS Indy:
  18. #18 Re: Harmonic Balancer Bolt Removal
    Yeah just pull the fuse for the fuel pump and run it until it dies then crank for a few seconds make sure it doesn't start then put the breaker bar on then crank it. Shouldn't take much to do it.
  19. #19 Re: Harmonic Balancer Bolt Removal
    Marysville WA
    Easy enough, ill let you guys know how it goes thanks!!
  20. #20 Re: Harmonic Balancer Bolt Removal
    Jersey
    ive used the starter trick 2wice, both worked like a charm, i had my ignition wires off the spark plugs and fuel pump fuse pulled, and of course s/c and serpentine belt removed
    16' wrx sti- stock
  1. new harmonic balancer, now got KR
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2012, 07:31 AM
  2. Harmonic Balancer-no Stock??
    By diamondz101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2011, 08:18 PM
  3. help with harmonic balancer
    By Alcalypse in forum General Tech Discussion
    Last Post: 01-13-2011, 09:04 PM
  4. Harmonic balancer puller
    By TorqueAutoMotiv in forum Shops and Community Heroes
    Last Post: 10-02-2010, 03:49 AM
  5. How to hold Harmonic Balancer Still to Remove Crank Bolt?
    By pontiackid in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2009, 09:00 PM
