No misfires.
Long-Term FT: Hit as low as -14.1 while driving, don't think it ever got above +8.
Timing: 25* idling in drive, 32-36* at low speed, low-rpm, 17-18* at WOT.
Not sure then...ever replaced the following?
Fuel Filter?
PCV?
Spark Plugs?
Plug Wires?
ICM?
Coils?
Vac lines?
Checked the Rubber "T" fittings around the top end?
Cleaned the IAC/TPS/MAF?
It probably just needs a tune up then brutha.
When you change the plugs/wires/FF/PCV...sand down the coil terminals a little bit to clean them...and then remove the ICM and have it tested at your local auto parts store to make sure it is in good working order. I'd also unplug the battery when you do that...because I've grounded mine out and it was a nice 150 dollar fix for stupidity.
Lifetime warranty plug wires...from your local auto parts store.
Autolite 605's...gap them at .050"
Whatever fuel filters/PCV valves they have there...
Testing the ICM is free...
Could just need cleaned too.
I've seen plenty that are just full of dirt and grime.
When you remove the coils (5.5mm bolts btw...tiny bastards...just a clean towel to wipe it off and the bottom of the coils. Like I said before...clean the coil terminals as well.
I know it has been over the weekend...any updates broham?
Been working mostly.
Haven't really changed anything. It did it again once yesterday.
Also yesterday: unplugged battery temporarily, when attempting to plug it back, it was sparking heavily and once connected, the relays would click, then power down, then click, then power down, until i unplugged it again, and during all this, when started would just die. I left it off, made a couple calls, plugged it in for ****s in giggles. No heavy sparking, no relay clicking, started normally, ran normally.
A long shot here, but check you PCM plug in's.
Today at school we were working on a riviera and the connectors in the back of the pcm were coming loose and casuing tons of problems. I smacked the glovebox (where the pcm is) and the car almost died, smacked it again, car died. Cleaned the connectors and plug it back in and tighten it all down and runs great. Might be worth a look.
Okay, so, still having troubles. To sum up what I know so far:
- Once in awhile, the car will act like it's being choked for fuel, acceleration will be rough, as well as idling, with the potential to stall at idle.
- Sometimes feels very lacking on power, and shifts hard
- Rarely will drop to idle when stepping on the brake, rather than down to 12-1400 or so
- Frequently idles slightly rough (just a bit, not nearly like when it's choking hard)
What I did:
- The day before this started, I replaced the alternator
- 2 days ago, I put the old one back on, problem continued, and as of today, the old alternator stopped charging, whether it's related, or the alternator suddenly died, I haven't a clue
fule pump on its way out the door, pressure regulator, failing o2, egr....my o2 seemed fine but every once in a while would spike either way irratically till i noticed my wideband and narrowband were always opposite reading of each other. replaced o2 which seemed fine and no more issue
