yea its gtp pcm with a gt trans bin
It starts but doesn't run well, yea i still have the l36 map
I was looking overkill's pcm and thinking about getting one
Are you sure you have the MAP wired correctly? Sounds like a bad MAP to me not a bad PCM
Do you have access to the file that is on the PCM or better yet...Who did you get the PCM from?
I'm pretty sure I did, i just matched wire colors up.
I'm tring to find the post of the guy I bought the pcm from, but they all seemed to disappered. I know he lives up here by me in Sioux Falls, South Dakota. He drives a 99 ( i think) black 2 door gtp
It doesnt sound like its running properly.
still haven't figured it out, it won't start with the map plugged in. I've tried different maps, no luck. I can start it then plug in the map and runs fine
What MAP are you using and what file?
map is a 2 bar and pcm is 98... info on page 1
my guess is the tune is not correct. you say the pcm is a 98 but you have a 99 tb/maf. the base files are diff there. who knows what else is incorrect in the file. if you have access to a DHP i can give you a hand setting up the file. my money is on the maf not set up correctly and the improper matching of maf tables...
have you tried to wire back in a l36 map?
what all have you tried in the past 2 years?
The tune is from zzp so that's good but I am also using a fuel rail from zzp come to find out that the fuel rail they gave me was using a gen 1 fuel regulator that wasn't keeping pressure and letting fuel in the vac line so they are making me a new fuel rail with the gen 2 regulator so we shall see how it goes
