Thread: Help help gtp wont start
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
  1. #1 Help help gtp wont start
    Mar 2012
    RIVERDALE IL
    the other day my car was losing power while driving kept shutting off but start right back up i figure it was the fuel pump because it was humming real bad so i change the fuel pump with a new fuel pump when i put the new fuel pump in the car ran perfect wiith no issues but when i cut the car off it sat for a few hrs came back out the car wouldnt start anymore but now i just look at the box on the new fuel i bought from this guy it say for 99 and 00 is that the reason my car wont start even though it ran for a while with that fuel pump and another thing my car is a 97
  2. #2 Re: Help help gtp wont start
    St. Louis
    So when your car wouldn't start anymore, it would just crank and crank but not fire up? When you turn the key to the "On" position do you hear the fuel pump prime for a few seconds?
    May want to check your fueses first, then go from there. Could also be the fuel pump resistor.
  3. #3 Re: Help help gtp wont start
    Mar 2012
    RIVERDALE IL
    yea when i turn the key i hear the fuel pump it crank but wont start up its driving me crazy but could it be that i have a 99 fuel pump in a 97 ?
  4. #4 Re: Help help gtp wont start
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by FordMan77 View Post
    If that doesn't work make sure you have spark. Unplugging the MAF may get you running too.
  5. #5 Re: Help help gtp wont start
    Mar 2012
    RIVERDALE IL
    but do it matter if its a 99 fuel pump in a 97?
  6. #6 Re: Help help gtp wont start
    Apr 2009
    Fort Worth TX
    Fuel pump is compatible, I believe.
  7. #7 Re: Help help gtp wont start
    Ohio
    is it a whole assembly or just the pump? and is it an n/a pump or supercharged?
  8. #8 Re: Help help gtp wont start
    Mar 2012
    RIVERDALE IL
    it just the fuel pump
  9. #9 Re: Help help gtp wont start
    Ohio
    i hope you got the feed hose on tight. it sounds like its leaking pressure. i hope it was a venturi style, else your gonna be ****ed here soon
  10. #10 Re: Help help gtp wont start
    Mar 2012
    RIVERDALE IL
    yea the hoses on tight it act like its want to start but it would shut right off like its out of gas
  11. #11 Re: Help help gtp wont start
    Ohio
    so its the resistor. open up the fuse box in the engine bay, pull the fuse pump relay and bend pin 85...reinstall and see if the problem still occurs
  12. #12 Re: Help help gtp wont start
    Apr 2009
    Fort Worth TX
    The pump should be enough to get the car running but if it's the wrong style you may cause a lean condition when the engine is at higher RPM.
    I think this is what 99pgpgt is talking about.
    Do you have the ability to check the fuel pressure at the schrader valve?
  13. #13 Re: Help help gtp wont start
    Mar 2012
    RIVERDALE IL
    rico i check the scrader valve nothing but air came out now the car startin with no problem thanks wow that minor problem my car havent been runnin since thursday
  14. #14 Re: Help help gtp wont start
    Apr 2009
    Fort Worth TX
    Great!...I guess the system needed primed?
    Like 99pgpgt said, make sure it's the correct pump for the supercharged motor. You don't need any more problems.
  15. #15 Re: Help help gtp wont start
    Mar 2012
    RIVERDALE IL
    well after i let the car sit for a while the same problem happen i got it started again drove around with no problem now it sat for like a hr wont start again damn car pissing me off
  16. #16 Re: Help help gtp wont start
    Apr 2009
    Fort Worth TX
    Have you replace the fuel filter? Is there air in the system again? Did you remove the relay and disable the fuel pump resistor yet like 99pgpgt said?
  17. #17 Re: Help help gtp wont start
    The Boss Iceman6669's Avatar
    Jun 2011
    Have you tried getting it to start using starting fluid...That would tell you for sure if it is your Fuel that is the issue...
    2011 F-150 Yote powered
  18. #18 Re: Help help gtp wont start
    Mar 2012
    RIVERDALE IL
    yea i remove the relay it still didnt start i havent replace my fuel filter i believe thats the problem i dont understand when it do start it start right like nothing wrong i'll shut it off it start right back up but soon i let it sit for a while the car act up and wont start
  19. #19 Re: Help help gtp wont start
    Apr 2009
    Fort Worth TX
    I can't understand why the hell you're getting air in the system. Are you sure the lines going into the pump are secure? If the pump is sucking air it will ruin the pump...fuel acts as a lubricant.
  20. #20 Re: Help help gtp wont start
    Mar 2012
    RIVERDALE IL
    yea the lines are is tight it wont even attempt to start anymore frustrating
  1. Need Help. '99 GTP wont start and I don't know why!
    By Agentlongwood in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 06:52 AM
  2. car wont start need help
    By 2001goldGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2011, 09:02 AM
  3. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  4. Wont Start Please Help
    By Honchop1 in forum General Tech Discussion
    Last Post: 09-11-2010, 08:27 PM
  5. Car wont start need help!!!!
    By drums4life0922 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2008, 09:34 AM
