Thread: My car temps?
Results 1 to 10 of 10
  1. #1 My car temps?
    Aug 2008
    SoCAL
    So I recently purchased an '02 GTP. It runs really well. I have noticed that the water temp isnt getting warm/hot. Example: I drive to work at 85mph, outside temp 75* and the car gets to about 170-175. If I stop or drive 55mph it will rise to about 180-183. It rarely, if at all, gets over 185. Even when its 106* outside and i'm on the freeway doing 85mph.
    Is this normal? I have not looked at the t-stat yet, i was gonna wait to hear from you all here first.
    Ed
  2. #2 Re: My car temps?
    Feb 2008
    Sounds like a thermostat to me!! It is either missing, stuck open or it opens to early.
    Good luck!!!
  3. #3 Re: My car temps?
    Aug 2008
    SoCAL
    Quote Originally Posted by Blown97 View Post
    Good luck!!!
    now for the magic question - 180* or stock? I do plan on modding adn going to atleast 3.4 pulley in the near future.
    Ed
  4. #4 Re: My car temps?
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    108* if your going to try and run a 3.4" pulley. If you are hoping to get a 3.4" pulley w\o Kr then also make sure you plan on getting a cold air intake, some exhaust work [a downpipe at the very least] a new PCM (or tune) and colder plugs.
    2006 Grand Prix GXP
  5. #5 Re: My car temps?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by getsumbaby View Post
    Ed
    Can you tell if the fans are coming on to maintain the temps you mentioned? If so then perhaps you have a 180* drilled thermostat and the fans are helping it do the job.
    Also are you using a scanner to verify those temps?
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  6. #6 Re: My car temps?
    Aug 2008
    SoCAL
    ok - i am nt using a scanner. And both fans turn on at 185 (according to the gauge).
    Thats the prob buying used - i dont know what was done to the car yet! Do you think the PCM has been programmed to turn the fans on at 185?
    Ed
  7. #7 Re: My car temps?
    St Louis MO
    Ed
    If the fan comes on at 185* assuming your gauge is correct then the PCM has to have been ajusted. Here are the stock settings.
    My car temps? Attached Images
    2010 Camaro SS LS3
  8. #8 Re: My car temps?
    GT Level Member riceburner's Avatar
    Aug 2008
    denver, co
    Is there any way to tell if you have a 180*?...i am thinking mine might asw well...what do the stock cars run at?
  9. #9 Re: My car temps?
    PA
    Quote Originally Posted by riceburner View Post
    The best way is with a scanner to read exactly what the temps are. The gauge on your dash is highly inaccurate. With my 195° stat in, my gauge reads somewhere around 160°. But my scanner shows that it is 190-195°. So the best way to verify is with a scanner.
    Don't ever trust the dash temp gauge except for general cold/hot.
    2001 GSE
  10. #10 Re: My car temps?
    Aug 2008
    denver, co
    ah good to know. i will probably just replace it anyways...hahaha
    so one more ? what is different about the 180 drilled as compared to the normal 180*?
  1. Lets talk about temps!!!
    By Blown97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2008, 11:36 AM
  2. theorizing on rising engine temps
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-11-2008, 11:37 PM
  3. Monitoring IC temps
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 09:28 PM
  4. Tranny Temps
    By 04CompG in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-09-2008, 03:32 PM
  5. 70+ Degree temps for 2 days and then roof falls in!!!
    By GeddyLee in forum Off Topic Discussion
    Last Post: 03-05-2008, 10:16 PM
